cchrishefish
Yes, they also say it is electronic, bad listingMechanical. See the coils Rusty was talking about?
I have another Wells/Airtex 1V1067 new in the box. I can meet you at the C-Store at Exit 42 on the Thruway today. Not late, though. $25. Or delivered to Syracuse today for $50. I would need to know no later than noon.This sure puts a delay in my ignition upgrade this weekend. I do not see any parts stores in my area that have one in stock. I do have the 60 amp alternator.
I think their description is generic when they talk about their circuit boards. I think the Echlin one is the one I bought. Just like the FBO one that Scuder mentioned in his last link above.Yes, they also say it is electronic, bad listing
I appreciate your offer to meet me very thoughtful, I will just put this off another week, I will just mount the electronic spark box to the firewall for now, and possibly run my wires without actually connecting. I work in the VA hospital on second shift tonight. And I am currently waiting for my Wife's new Rav 4 to receive its first free service.I have another Wells/Airtex 1V1067 new in the box. I can meet you at the C-Store at Exit 42 on the Thruway today. Not late, though. $25. Or delivered to Syracuse today for $50. I would need to know no later than noon.
I think the FBO is probably the best choice, made in USA.I used to live in the neighborhood just south of the VA Hospital. My Aunt was an OR nurse there. She retired many years ago. Those few blocks bordered by Route 81, Oakwood Cemetery, and SU/ESF were filled with single family and duplex homes built in the first half of the 20th Century. Lots of families and students. I think they're all gone now, mostly replaced with parking lots and university buildings.
When the Carrier Dome was being built, a construction worker had a Superbird as his winter beater. White, black bench seat, that long pistol-grip shifter handle, punched in nose cone, rotted quarters, and snow tires. I remember him once, slowly driving by me walking on the sidewalk in a heavy snow, and the exhaust was pretty blown out, too. My only car, a sweet '68 Road Runner was garaged of course, so I walked and bummed rides in the winter.
Here's the back of the FBO regulator. No resistor coils. You could easily have one by next weekend. PM me if you'd like the Wells/Airtex 1V1067 mailed for $15.
I think its a toss up in reality. If its essentially an open circuit, then you are correct. But if its simply a poor connection that flows some current then the VR will attempt to full field. I think that's what Del had in mind.Incorrect, a bad ground with the newer electronic regulator (triangle plug), will cause no charging. The regulator completes the field circuit to ground through the regulator case. If the case is not grounded, you do not have a complete field circuit.
I currently have my original style voltage regulator grounded to my negative battery terminal.I think its a toss up in reality. If its essentially an open circuit, then you are correct. But if its simply a poor connection that flows some current then the VR will attempt to full field. I think that's what Del had in mind.
Same, but I've been using the p-part style regulator since I built the car in '88-9. Unfortunately I can't currently recommend any of those. Mopar Performance recommended them as needed with their ECUs. After I had gone through a couple, they had revised their recommendation to stating the p-part regulators were for racing. This would be around 90-91. But then had one last over 10 years with a MSD 6t. So I don't really know what the issue with them was. I've had Echlin VR 1001 last about 5 years and a couple Standard VR-128s that haven't made it that long before flaking out.I currently have my original style voltage regulator grounded to my negative battery terminal.
You know how the points regulators are at idle. They chatter like false teeth. Then with the blower and the turn signal on you're below 12v then above, below 12, then above. The electronic regs. are much steadier and will deliver a more constant signal for the electronic ignition. Just my guess.So somebody tell me why the electronic one is "better" for a certain type of ignition system. I haven't really seen that divulged yet. Seems to me all it would be "better" at would be eliminating the mechanical end of the regulator. But, if it's a low quality one, "better" certainly is subjective, isn't it?
I agree 100%So somebody tell me why the electronic one is "better" for a certain type of ignition system. I haven't really seen that divulged yet. Seems to me all it would be "better" at would be eliminating the mechanical end of the regulator. But, if it's a low quality one, "better" certainly is subjective, isn't it?
Is that chattering in the VR ? or is it the ripple current showing through because the rpm is so low? I see it when using an the electronic VRs mentioned in my post above with higher output squarebacks and revised squarebacks.You know how the points regulators are at idle. They chatter like false teeth. Then with the blower and the turn signal on you're below 12v then above, below 12, then above. The electronic regs. are much steadier and will deliver a more constant signal for the electronic ignition. Just my guess.
I had an analog voltmeter attached to the temp gage connector. It bounces back and forthjust like you describeOn my instrument panel voltage regulator for example, it's not quite "teeth chattering" frequency. I can sit there and see it in the gauge operation. It's more like open....close...open...close. "About" that slow. You can see the gauges fluctuate up and down very slightly. The main voltage regulator may work much faster, though, I don't know. Regardless, it works.
I can hear it and see it on the amp meter. Turn the headlights on at night and the lights do flicker at idle. The electronic regulator didn't do that.Is that chattering in the VR ? or is it the ripple current showing through because the rpm is so low? I see it when using an the electronic VRs mentioned in my post above with higher output squarebacks and revised squarebacks.
That's funny, on my Barracuda I can't hear it but I can see it like you describe with the electronic regulators I mentioned above. I'm going to try that FBO regulator and see if its any different.I can hear it and see it on the amp meter. Turn the headlights on at night and the lights do flicker at idle. The electronic regulator didn't do that.
