Properly prepped EQ heads.
This leads to incorrect thinking. This type of incorrect argument could be used to 'prove' that the iron headed engine is shedding MORE heat and thus being less efficient. It would shed more heat direct to the air through the heads BECAUSE is it hotter, and thus is losing more heat to the surroundings. But of course, the reality is how much heat goes everywhere OR how much comes out of the crank. (Dyno output). It all comes out in dyno measurements, and all I have seen from actual testing is that there is no conclusive difference.The energy the motor makes is in many forms. Heat is one that cannot be used unless its kept in the combustion chamber as pressure (or used to drive a turbo) Iron is superior to aluminum in this trait. If the mags chose to measure everything about the motor (ie. coolant temperature, radiator efficiency, temperature rise of the dyno cell), etc) they would see the sum of all energies produced. if a motor is giving off more heat from the same amount of fuel burned, it is using less to turn the crank.
YUP! would not get out of its own way until about the chrismas tree, then took off like a bat out of helll. It loved to rev, but you cant make up what you loose in the first 60 feet.Did they kill the low end?
So all of our banter comes down to this? Sheesh, that didn't even get us a beer and a game of pool together. Run what you brung... It all comes out in dyno measurements, and all I have seen from actual testing is that there is no conclusive difference....
Iron heads are used for "door stops" around here
Thanks for all the info so far. As far as the cars usage, just street. I have no intention of breaking stuff at the dragstrip, although that would be a dream. Here's some info on the car so far. Dana 60 rear end with 3.55 posi. KB 243 pistons, .030 over. Forged crank. 4 speed. That's where I'm at so far. I'm not trying to squeeze every last tenth out of the car, just mostly wanna scare some women and children at the cruise night scene...
Throw this into the mix. 2 smallblocks we are finishing up in the next week . Which will be faster in the same car (horsepower guess) . Not my parts choice on 1 of the motors. #1 1976 Dodge truck 318 block .030 , scat 4" kit 390 cubic inches ,compression 9.6-1 using cometic .027" gaskets. OTB edelbrock heads set up for roller cam . Lunati 271/279 advertised hydraulic roller , OTB pro-comp dual plane intake with FAST fuel injection and hooker 1-5/8 headers.
#2 1975 360 block .020 cut to zero deck using speed pro pistons for 10.1-1 compression using felpro .039" gaskets bare rhs-x heads.comp longer valves 1.92 & 1.65 beehives , about 4 hours port work on the bowls ,chambers , runners , guide boss slim , back cut valves ,might come close to IMM otb . lunati 243/251 @.050 solid flat tappet , worked holley strip dominator with a worked quick fuel 750. and TTI 1-5/8x1-3/4 headers.
Another note, I do have a set of X heads. I'm wondering what the cost of a valve job, port and polish would be?? I will make some calls on that locally, but are there any guesstimates on what that might cost?
As you ask, ask about multi-angle valve jobs and if they can open up under the seats with a Serdi machine. Those are lower cost steps to get a bit more flow (versus real porting work). The Serdi machines are not everywhere, and I don't know if there are limitations on when they can be used, so that may not work out.Another note, I do have a set of X heads. I'm wondering what the cost of a valve job, port and polish would be?? I will make some calls on that locally, but are there any guesstimates on what that might cost?
See if you can run down an old school machine shop in your area that does a lot for track work; IMHO, that will be your best bet. And, the shop that did Bob Glidden's heads back in the day is around Indy somewhere; dunno the name, dunno if the older guys are still there, and the price may be waaaay up there, but it might be worth running down. Are you anywhere near the Toledo area?
