WHEN are you going to find out if it was worth it ? Do you mean the track or flow bench . Either way I bet there will be an improvement , you have opened up a shitload and got rid of obstructions . has to help I CAN SAY I'VE NEVER SEEN AN INTAKE OPENED UP SO MUCH the walls of the ports are so thin !Thanks. I appreciate it and I figured it was doable but like I said it’s not worth the effort unless it shows me some crazy performance numbers. I get bored on projects that take this amount of effort anymore and it takes time away from other projects that I should be working on.
