Edelbrock head and ported Indy intake
Thanks. I appreciate it and I figured it was doable but like I said it’s not worth the effort unless it shows me some crazy performance numbers. I get bored on projects that take this amount of effort anymore and it takes time away from other projects that I should be working on.
WHEN are you going to find out if it was worth it ? Do you mean the track or flow bench . Either way I bet there will be an improvement , you have opened up a shitload and got rid of obstructions . has to help I CAN SAY I'VE NEVER SEEN AN INTAKE OPENED UP SO MUCH the walls of the ports are so thin !
I’m sure I will have it on the bench again but I gotta have this engine race ready by the 1st or 2nd week of May so hopefully I get one test session before our race season begins. The short block is patently waiting.
Different intake and I don’t know when I will get to track test it but the last Victor340 patiently waits on the shelf to be put to use on something. I’ve never put this much work into one of these so I’m super excited to try it.
What, like Walmart pic’s:lol:
I really enjoy seeing what you are doing and makes me think of what is possible.
Different intake and I don’t know when I will get to track test it but the last Victor340 patiently waits on the shelf to be put to use on something. I’ve never put this much work into one of these so I’m super excited to try it. View attachment 1715724803View attachment 1715724804View attachment 1715724805
i'll be waiting for results , so far my victor is not much better that the ported airgap ,40 less tq 10 hp more
going to work on it cause as it stands it sucks
Did you try a 1 inch spacer on it. Matt and I both run one but one of the reasons we do is it’s tapped for our lean-out valves for warm ups with alcohol
Sounds like the typical trade off.
