Edelbrock intake thermostat gasket?
wes beem
ohio
Anyone know where i can get a thermostat gasket for my eddy intake? Jegs sells the eddy 63mm thermostats but no gaskets
I'm American so I only know inches. If that's the small thermostat housing, Felpro probably makes them and maybe Chrysler dealer has them.
What the hell is 63mm’s?
AutoZone has always had either gaskets for me.
Fel Pro 35063
Your welcome, I just installed one on my AirGap along with a Stant 195 deg, tell those old guys that mm/25.4=inches easy to remember:poke:
we went to AZ and asked for a stock magnum Tstat, got home realized it was way too small when it fell right into the intake, so then we went back and got an LA one, same problem...finally we figured out eddelbrock uses a non proprietary oddball size that nobody at a parts store even stocks....only place i found one was jegs/summit...really annoying..
66mm/25.4 mm per inch = 2.48 inches which is pretty darn close to the 2.5" one listed above. If America would ever get on ball with the rest of the entire world and convert to the metric system, we would all know that.
I have never heard this before? My Edelbrock Air Gap takes a standard thermostat and gasket.
Why should we change our system for foreigners. We did very well before some *** hole said lets go metric.
