MopaR&D
Nerd Member
Just to lay out my understanding of how tuning affects emissions since I have to deal with that in Colorado on anything newer than 1975...
Advanced timing increases combustion temps in the cylinder and produces more NOx, somewhat more CO. Retarding does the opposite, that's why smog-era cars run very little advance. Also releases more heat to the exhaust and coolant system instead of keeping it in the cylinder.
Running lean actually produces less total heat but the burn rate is slower so the heat rejected to the exhaust and coolant is actually higher hence why they run "hot". Abundance of oxygen helps ensure there are 2 oxygen atoms available for every carbon atom so you get CO2 instead of CO with each burn. And as has been said it keeps the exhaust system a lot hotter which helps the mixture continue to burn more completely after it's left the engine.
The tricky part is dealing with HC when you have a performance camshaft. A lumpy idle is sorta like controlled misfiring which just DUMPS unburned fuel out the exhaust and that's your high HC. Now what makes it tricky is if you retard the timing to heat up the exhaust you'll end up making idle quality worse which may cause more misfiring which may then actually increase HC.
So I agree with what others have said, leave the timing alone for now and just lean the **** out of the idle circuits till it barely runs. One trick that worked for me when my 1988 Fifth Avenue wouldn't pass (original cats were long burned-out) was putting a few gallons of E-85 in the tank. I'd guess it was around 60/40 premium (higher octane + better detergents also helps) gas to E-85. Worked like a charm and afterwards I just filled up the tank the rest of the way with regular gas and took it easy until that tank was empty.
