Flywheel removal question?
Transmission and Drivetrain Tech
  1. Troub
    Troub 67 Dart 270, 225 slant six
    391
    85
    Jul 25, 2018
    Florida
    Local Time:
    12:48 AM
    904 trans, 1967 slant six,......so how would you get this flywheel off?
  2. yellow rose
    yellow rose Doctor of Thinkology.
    20,408
    16490
    Jun 19, 2015
    Living on the razors edge
    Local Time:
    10:48 PM
    If you mean the ring gear...you don't.
    Take the converter to a local converter shop (almost every big city has at least one) and they will cut that one off and weld a new one on.
    • Thanks! Thanks! x 1
    • Dana67Dart
      Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
      3,525
      2084
      Jul 16, 2017
      Northern Colorado
      Local Time:
      11:48 PM
      What you are looking at is the torque converter. It should just slide forward off the input shaft of the auto trans.
      • RustyRatRod
        RustyRatRod Weenie idiot loser. FABO Gold Member
        58,502
        28916
        Jun 7, 2010
        Georgia
        Local Time:
        1:48 AM
        If you can weld, you can do it yourself. Just remove the converter, cut the welds, remove the ring gear, clean the ring gear seat area and weld a new one on. Or, you can probably buy a reman stock converter for around 100 bucks with a new gear already on it.
        • Troub
          391
          85
          Jul 25, 2018
          Florida
          Local Time:
          12:48 AM
        • RAT ROD AL
          RAT ROD AL I know just enough to be dangerous FABO Gold Member
          3,041
          3323
          Jan 18, 2013
          St. James City. FL.
          Local Time:
          1:48 AM
          I have a good 67 torque converter .
          Free if you want it. I'm in FLORIDA to.
          • RustyRatRod
            58,502
            28916
            Jun 7, 2010
            Georgia
            Local Time:
            1:48 AM
            The trans shop will probably recommend a new converter. I would actually endorse that.
            .....OR Al says he has one. If he says it's good, it is. He's a good dude.
            • Troub
              391
              85
              Jul 25, 2018
              Florida
              Local Time:
              12:48 AM
              Thanks AL, the converter is fine I think, the teeth in the ring gear are sheared in a couple spots. Your converter have a good ring gear?
            • RAT ROD AL
              3,041
              3323
              Jan 18, 2013
              St. James City. FL.
              Local Time:
              1:48 AM
              Yes I believe it does. I will have to dig it up and check it.
              • RAT ROD AL
                3,041
                3323
                Jan 18, 2013
                St. James City. FL.
                Local Time:
                1:48 AM
                Hey Troub, where you at in FLORIDA?
              • pishta
                pishta I know I'm right....
                16,497
                6182
                Oct 13, 2004
                Tustin, CA
                Local Time:
                10:48 PM
                The FSM manual ('repair, dont replace' must be their montra) shows you how to cut the welds with a cold chisel and them hammer the ring off. Debur the edges and throw the new ring in a pan of hot water (?) or some heat source and then quickly get it centered onto the convertor before it shrink locks on. then tack weld it carefully so it doesnt warp. up through 67 convertors are small snout, remember that.
                • Dana67Dart
                  3,525
                  2084
                  Jul 16, 2017
                  Northern Colorado
                  Local Time:
                  11:48 PM
                  OOPS.... Captain Obvious here!
                  You meant the damaged ring gear ON the torque converter.
                  Slapping forehead!
                • pishta
                  16,497
                  6182
                  Oct 13, 2004
                  Tustin, CA
                  Local Time:
                  10:48 PM
                  On the farm, you would hit those teeth with a stick welder and file back to shape. I think a ring gear is about as expensive as a rebuilt convertor...
                  Here are some cross reference part numbers for a common 904 convertor ring gear
                  • Industry Part ID: RG-130H, CH-RG-130 (Sonnax), 3515203, 130C, 600-3105, CC130C, 416101, 6003105, RG21, ZA-510, FRG-130C, 4401, RG130C
                  • Outer Dia: 13.195"
                  • Inner Dia: 11.19"
                  • Width: 0.33"
                  • External teeth: 130
                  • Troub
                    391
                    85
                    Jul 25, 2018
                    Florida
                    Local Time:
                    12:48 AM
                    Pensacola, far western panhandle. You down south?
                  • Troub
                    391
                    85
                    Jul 25, 2018
                    Florida
                    Local Time:
                    12:48 AM
                    I really need to learn how to weld.
                  • toolmanmike
                    toolmanmike FABO Staff Staff Member FABO Gold Member
                    46,792
                    31057
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    12:48 AM
                    Hey guys, this isn't a sale or wanted thread. Please discuss this with a personal message. Thanks.
                  • pishta
                    16,497
                    6182
                    Oct 13, 2004
                    Tustin, CA
                    Local Time:
                    10:48 PM
                    Those tack welds are just scratching the stick to the joint and letting it arc flow about 1/2 second. Hard part with a stick welder is the stick 'sticking' and just turning to a red hot smoking wire, usually too low amperage. Flux MIG welder is real easy, just hover over it about 3mm and hit the trigger.
