what oil pressure does engine have? did you test it before firing engine? with a drill motor?
You still never told us how much oil pressure it has on start up when the gasket blows out. 50# shouldn't make that happen. If it pegs a 100# gauge I'd bet you have a stuck pressure relief valve in the oil pump. Especially if the engine grenaded. Any metal big enough to go through the pick-up screen will get in the pump and relief valve.I did test it with a drill before startup. It ran over 50 lbs of pressure and blew the oil filter o ring out just priming the motor. I reused a melling high voluem oil pump. It was running on a motor that broke a piston and split a cylinder wall. The pump only had about a thousand miles on it if that much.
I drilled 2 holes in the mounting plate and put on a wix filter. same result. It blew the o ring again. this is the 4th filter.
Next question is can you pull a 360 la oil pan without pulling the motor? It is in a 1994 plymouth duster front sump pan.
Anyone got an original front sump pan and pickup for sale?
Didn,t mean to hurt you thought pattern, but a front sump oil pan is one with the sump for the oil pickup is in front of the motor. Trucks use a rear sump pan for the oil pickup. Older cars use a front sump.What the heck is a 1994 duster with a front sump pan?????
Guys I,ve run out of ideas so I guess I,ll pull the pan tomorrow and install a new oil pump. I think I,ll go with a stock pump and see how it works. I appreciate the input.Didn,t mean to hurt you thought pattern, but a front sump oil pan is one with the sump for the oil pickup is in front of the motor. Trucks use a rear sump pan for the oil pickup. Older cars use a front sump.
I agree 100% with this.You still never told us how much oil pressure it has on start up when the gasket blows out. 50# shouldn't make that happen. If it pegs a 100# gauge I'd bet you have a stuck pressure relief valve in the oil pump. Especially if the engine grenaded. Any metal big enough to go through the pick-up screen will get in the pump and relief valve.
Well, not to hurt your thought pattern either, but mopars use a mid sump pan..... trucks use a rear sump, and real early trucks used a front sump. I have NEVER seen A a body mopar with a front sump pan.Didn,t mean to hurt you thought pattern, but a front sump oil pan is one with the sump for the oil pickup is in front of the motor. Trucks use a rear sump pan for the oil pickup. Older cars use a front sump.
It never gets to max oil pressure because it blows the o ring out of the filter then looses all pressure.I agree 100% with this.
Hang onIt never gets to max oil pressure because it blows the o ring out of the filter then looses all pressure.
big block
Got to be a reason why the pump is building so much pressure. You could put the pump in a bucket and if the relief valve is stuck it will build pressure until something blows.Hang on
There is a cup-plug just upstream from the pump. It's purpose is to separate the oil coming from the pump , from that going to the mains.
I agree, but if that passage is plugged/restricted, and even if the relief valve was correctly functioning, It would not take much pressure to blow the filter off, oil is not compressible, and I bet the pump has enough reserve to blow it, and not enough bypass capacity to prevent it. But of course I have never tested it so it's just a thought,lol.Got to be a reason why the pump is building so much pressure. You could put the pump in a bucket and if the relief valve is stuck it will build pressure until something blows.
That is a possibility. There are a lot of "leaks" in the oiling system to reduce pressure once it builds up. . We will see when the OP replaces the pump. I still can't believe if the pressure relief was working properly the pump wouldn't build enough pressure to blow the filter. Time will tell. It's another one of those issues that is hard to diagnose over the internet.I agree, but if that passage is plugged/restricted, and even if the relief valve was correctly functioning, It would not take much pressure to blow the filter off, oil is not compressible, and I bet the pump has enough reserve to blow it, and not enough bypass capacity to prevent it. But of course I have never tested it so it's just a thought,lol.
and the test is easy and quick.
I wish I was accused of that! Just once in my life!I didn't say it did. But if someone drove it in to deep .........
if someone drove that plug in too deep .........The oil flow would stop right there, and the pressure would instantly rise, and POP goes the filter.
I've only ever replaced that plug once, and I carefully measured the distance to the stop. But the plug stopped when it hit that ledge, anyway. I can't imagine the force it would take to drive that plug any further.
And I'm not saying this is OPs problem. I'm just suggesting this is an easy, quick test. Just pop the pressure sender and watch the geyser flood the hood, and everything else too. The sender only measures pressure, and not flow, so it could read the pressure accurately, yet with the flow nearly stopped up, My opinion is the pressure relief inside the pump can only bypass so much,and if it's not enough then the filter is the weak link.
I mean the drill is what rpm 750, maybe 1000,so that's equivalent to double that in engine rpm, and at 10 psi per 1000, there should only be way less than bypass pressure there. There has got to be a stoppage somewhere upstream of the filter,and/or not far down the oil-gallery, else the bearings would be leaking it out. That cup-plug was just my first thought.
Yeah you can leave it out, and then you can take the filter off too and just put a plate there, for all the good the filter would then do.
The plug everybody is talking about is straight down below the oil pressure sending unit. You can take a long rod and stick in there and it should be approximately 8 in below the China wall.
When you had the adapter plate for the oil filter off of the side of the block was the screw-in plug in the passage underneath it. Or has it been left out.
if a block is tanked or baked a lot of times machine shops will drive that plug out and replace it. But the only way to replace it is to drive it down from up above out through where the main cap is.
What year is this car?
