I'm thinking of going hydraulic cam for my 273/302 build the reason is I'm trying to preserve as much bottom end as possible so after reading about Rhoads lifters they might be worth switching to hydraulic since I'm gonna run a 280ish with .525ish lift with 1.6 rockers. The question will a hydraulic cam work up to 7000-7300 (is where i want my valve spring to work too) with light enough valvetrain? I'm gonna run under cut hollow ford stem valves 1.85-1.55 with beehive springs and titanium retainers.
