Green Envy
Green envy had been mentioned as a dirty lady before.With thatMagnum hood,and fresh sheetmetal,looks like a hollywood actress going under the knife.Nice people helping you,Cliff.
Yeah great people and members here. She will be a beauty when she is finished.
We are taking our time because of the heat,110* today. So we got the freeze plugs, got the crank in and used plasti gauge to check tolerances and torque down. Put the rings on all the pistons,chased all the threads, They didn't let me do much,Karl, Asa, my middle son did most of all the work.
Sounds good... Wish I could be there.
Man Cliff that's hot, only 58* here and cloudy. I think we have only had one or two days that it has gotten into the 80's so far.
Sounds like you have a pretty good pit crew working with you.
Yeah they are doing a great job.
Kuddos to Karl! What a great friend! Im so glad to have had the pleasure of meeting you buddy. Cliff, you should have just about enough to get started in the fall now! Do you plan on manual or aftermarket power window?
I will be keeping the manual windows. Hope I can get started before then.
My brother in laws first car:Dark brown,71 383 Charger.Passed up a 400b/pistol grip 4 speed 72,for 5 bills,for no where to store it.
Here is the 360 block that Karl gave me with the Envy.
Here is Karl and Asa putting in the freeze plugs.
Here I am with Karl cleaning and chasing all the threads in the block.
Nice new Sealed Power Pistons and con rods.
We got all 8 pistons in without problems which was great. We did not know what was about to happen.
Karl had a dye to break apart while cleaning bolts, so we had to go find a replacement. 2 hours of driving around to find one. So while we were gone Asa cleaned up some surface rust on the heads with a wire wheel.
Here is when the first problem we ran into thanks to a machine shop because they wanted to take a short cut. Luckily Karl had a Mancini freeze plug kit which included the correct pipe plug. Once we got this taken care of (proper threaded allen head plug) we got the oil pump drive in.
Side note that plug was a bushing that the machine shop put in.
The heads are on. :blob:
