I am wanting to put different headlights in my 1974 dart, I want the kind where I can change the bulb but I also want to be able to put HID's in. Anyone know the best place I can find some like this?? Thanks
NAPA has these for about 40 bucks a side. Part number LIT 27012 and uses a 9003 bulb[/QUOTE
Is the wiring different??
The 3 prong connection on the bulbs is pretty much industry standard so any will plug right into you existing wiring. Since these modern bulbs draw much more current than OEM sealed beams, don't be surprised if the lights go off and back on intermittently. There isn't a fuse. The only circuit protection is a heat sensitive interrupt built into your headlight switch. Eventually the switch, the harness connection on it or both will melt down.
In some cases they've melted together to the point a new harness part was required.
All of this is why rewiring and adding relays is recommended.
All of the wiring as well as the switches are new and I have not had any issues and I have almost 2000 miles since may now not all at night I realize but a lot going to cruise in nights in the local area. The 9003 bulb is rated at 4.3 amps The h6024 old stlye bulb is rated at 3.2 amps so this should not cause any issues unless your wiring is in poor shape.
That's why I said "recommended" and not "must". Nobody knows their headlight switch is overheating until their lights go off.
These switches failed with stock bulbs too. It happened to me years ago so I can testify its quite a shock if you're on dark rural roads about 12 miles from home.
Good luck to all.
a sigle high beam or low beam bulb will have only 2, hot and ground. Dual function high and low beam bulbs require 3 wires, high beam , low beam, and ground.I ordered a set of projector headlights with HID's for my car, I'm just asking because all the HID sets I have seen on other cars only have 2 wires coming from there harness and plugging into the HID kit. The kit I ordered said it was for my car but I was just wondering what all 3 wires are for?? I'm sure one is ground and the other is power, but what is the other?
What did you do to fix this problem?
GE Nighthawk's with Relays. <$100, and illuminate better than many modern cars, and FAR superior to stock. HID's (had them OEM on my 08 vette) are definitely better, but $$$!
Im installing the napa lights I just did the 30 amp relay update, but Im waiting on a ceramic plug to come in which should take care of the plug. Right?
Acordding to the GE website the amp flow is about the same as the high quality 9003 bulb so I dont see why we need a relay.
40
All Mopar headlights should be converted to relays because they were borderline right from the factory. 45 years of bulkhead connector/ dimmer switch/ headlight switch/ other connections corroding hasn't made things any better. Besides, they weren't originally 9003s, they were 4000/ 4001, which draw even less
Just a side note, while your car is running and headlights are on check the voltage at the bulb connector. The voltage drop is about 2++ volts on average. The relays with a larger feed (#12 or #14) will get 13.8 volts to the bulb and a much brighter headlight. This and a new bulb and I think you'll be happy with the lighting system.
If i have 12.8 at the battery (car off) then I better have 12.5 - 12.6 at the head lamp or I have a issue that needs to be fixed in the circuit. switchs and wiring should not have a 2 volt drop or i would have about 6 ohms resistance in the circuit and that is what causes issues. Relays are mostly used to allow a low amp circuit control a high amp circuit. Again not trying to pick a fight just pointing basic laws of electricity.
4000/4001 are rated at 3.2 amp draw. 9003 are rated at 4.3
