Head scan...
Not saying it will help you. May be worth a try. Since I was all ready seeing a neurologist for other issues. I told him I was getting severe headaches, head would pound when I lowered and raised my head. My eyes felt like someone was sticking their fingers in them. He told me take 4 extra strength Excedrine and lay in a dark room. Twenty to thirty minutes should work.
Works like a charm. Stops them every time although i no longer hold off till it gets severe. I take them at onset.
Best of luck
Doc just called, everything is normal.....frigging head is pounding today...
You sound disappointed that the CT scan results were negative. That's a good thing! Headaches can be caused by a plethora of things.. High blood pressure, a bad tooth, TMJ, changing eye glass prescription, pinched nerve, a bad (for you) pillow, sinuses, light sensitivity, long hair, high pressure of the fluid in your eyes, poor posture, too much caffeine if you're not used to it, or even not enough caffeine if you are used to it, and on and on, things you wouldn't imagine have anything to do with it.
Doug, I'm gonna pray to the big man in the sky for you. I know how the head can ache for a few days continuously. Hope all works out!
Not disappointed, more frustrated. Truth is I have not felt right for several years now. Started testosterone injections and got a surge of energy but it was short lived. Headaches/dizziness have been going on for 6 months or so. Live with enough pain, between my back, shoulder, wrists and all the mental troubles enough is enough already. Would be lying if I said I have never looked at that loaded .45 and thought about how effortless it would be to pull the trigger at this point.
Doug, how much water do you drink?
Not as much as I used to, but then again I don't live in AZ anymore...I do need to start drinking more water. When I lived in AZ I would often drink close to 2 gallons a day....
Thanks
That is about what it feels like at times.
