70wayfarer
screwed in the arp head studs into the block, slipped the head gasket on and dropped the heads in place. all good so far. lubed the washers and top of studs and screwed the nuts on. here is the problem. all the long studs are short about 3-4 treads below top of nut. all the short ones have about 3-4 threads above the nut.
they are eddy rpm heads. has anyone encountered this before. either the studs are short or eddy has not milled the nut seats deep enough?
