inkjunkie
Heat or humidity? Which is the one making us uncomfortable? We don't have a/c....we will be getting a mini-spit next year probably. Right now the thermometer is saying 85* with 37% humidity. I can remember being in AZ with the temp at 85...January & February or so....with the humidity being in the single digits and being comfortable. Right now it is not hot in the house but it is a bit uncomfortable....is the humidity causing it? I have a good size de-humidifer from when I was doing some indoor "gardening". Bit unsure of bring it in as it generates a fair amount of heat.
I understand that part of what an a/c unit does is to remove the humidity. A neighbor had a mini-spit for his indoor "garden" and it was pumping water out if it. Granted, it was also drying out his plants as we went thru a noticeable amount more water with his garden....
