HELP!!! COOLANT WATERFALL!!
Discussion in 'Small Block Mopar Engine' started by Tyshiz, Jan 11, 2019.
Does a Non smog head fit a 1974 stock 318?
  1. Yes
    11 vote(s)
    100.0%
  2. No
    0 vote(s)
    0.0%
  1. Tooljunkie
    Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
    7,243
    5753
    Jul 22, 2017
    Manitoba
    Local Time:
    2:08 AM
    Never have i ever done a head without new intake gaskets.
    Its just a bad move. Over 10-30 dollars and a dozen bolts. Do it once, do it right.
    • Agree Agree x 4
    • Tyshiz
      Tyshiz Well-Known Member
      58
      13
      Aug 11, 2017
      Vermont
      View My Photos
      Local Time:
      3:08 AM
      I work with what i got and dont got much. Try to spend little as possible due to the amount ive already spent.didnt have anything but a new head
    • Tooljunkie
      7,243
      5753
      Jul 22, 2017
      Manitoba
      Local Time:
      2:08 AM
      Not a good reason to cut corners.
      What if it didnt have a noticeabke leak and dumped coolant into crancase? Cost of damage by far outweighs the price of a gasket set.
      I feel your pain, working with a bad back sucks.
      I was laid up and had to get my 2.2 turbo finished. I used a shop crane to pull and replace head.
      Its a horrible job with a sciatica flare up. I do this crap for a living, bad back or not i need to get the work done.
      • Agree Agree x 1
      • pishta
        pishta I know I'm right....
        13,568
        3323
        Oct 13, 2004
        Tustin, CA
        View My Photos
        Local Time:
        12:08 AM
        Guys check it out.....see the hole by #8 runner? IT has to be covered by gasket unless its a port for water heating something.....?
        <<EDIT>> That hole sure is there, BUT it does not enter water port, its between the bolt hole and the water port window so your gasket just didnt seal it. Its a blind hole with no matching head passage. Just collects dust with a normal gasket.
        • Agree Agree x 1
        • oldkimmer
          oldkimmer Well-Known Member
          9,593
          900
          Nov 11, 2006
          Kindersley, Saskatchewan,
          Local Time:
          2:08 AM
          What was the head from. What number is it. Did it come from a heavy duty truck engine as they have the coolant circulating thru the heads and intake. Let us know the details. If the shop did the work, have them make it right. Kim
        • oldkimmer
          9,593
          900
          Nov 11, 2006
          Local Time:
          2:08 AM
          Not to worry All factory intakes have that hole. Kim
          • Agree Agree x 1
          • pishta
            13,568
            3323
            Oct 13, 2004
            Tustin, CA
            View My Photos
            Local Time:
            12:08 AM
            yup, see my edit. But none go into water port. wrong position.
          • dazedand confused
            dazedand confused Well-Known Member
            100
            21
            Oct 3, 2010
            hollister mo.
            Local Time:
            2:08 AM
            Sorry typo : sealent not speaker ? Don't know how my spell check got that messed up
          • krazykuda
            krazykuda FABO Gold Member FABO Gold Member
            45,479
            10719
            Aug 20, 2007
            Orland Park, IL
            Local Time:
            2:08 AM
            I bought a 74 Valiant once where the guy did that...
            I've never done it, but seen it done once... Just once....
          • krazykuda
            45,479
            10719
            Aug 20, 2007
            Orland Park, IL
            Local Time:
            2:08 AM
            You have to assemble it in the proper order and use new gaskets... You can do it right, or do it over...
            Trying to cut corners and take the cheap way out can bite you in the @ss...
            You get out of it what you put into it...
            Get new head and intake gaskets, remove the intake and head, and put it on properly... Install a new head gasket and torque the head bolts, then install the intake with new gaskets and torque that to spec...
            Sorry about your back problems, some of us have to deal with that also... I was rear ended by a drunk 18 year old driver back in 1988 doing over 90 mph... I feel your pain...
            Agree...
            • Like Like x 1
            • Agree Agree x 1
            • Tyshiz
              58
              13
              Aug 11, 2017
              Vermont
              View My Photos
              Local Time:
              3:08 AM
              Thank you so much night dwelling mechanics of the world. Rested up im gonna do this crap again. What i know now is the i may have put that intake gasket backwards. Your right it should have sealed the hole i believe. Yup sciatica sucks. Had my discectomy. If it wasnt so cold this would not be a problem.
              • Thanks! Thanks! x 1
              • Tyshiz
                58
                13
                Aug 11, 2017
                Vermont
                View My Photos
                Local Time:
                3:08 AM
                Now i definitely need to drain the oil too. Im sure it must have dumped into case
              • Tyshiz
                58
                13
                Aug 11, 2017
                Vermont
                View My Photos
                Local Time:
                3:08 AM
                2d03 from surefire heads..... autozone.
              • Tyshiz
                58
                13
                Aug 11, 2017
                Vermont
                View My Photos
                Local Time:
                3:08 AM
                Big issue.... gasket maker doesnt work in 15 degree weather.....
                • Agree Agree x 1
                • Tooljunkie
                  7,243
                  5753
                  Jul 22, 2017
                  Manitoba
                  Local Time:
                  2:08 AM
                  Before i knew any better, my brother did this on a 302. I said i dont think you are doing it right. He pretty much told me to piss off. 3 times he changed head gasket thinking it was leaking, but it was intake gasket.
                  Blew it up on the way to the lake.
                • Tooljunkie
                  7,243
                  5753
                  Jul 22, 2017
                  Manitoba
                  Local Time:
                  2:08 AM
                  Rtv silicone= room temperature vulcanizing....
                • TrailBeast
                  TrailBeast Slightly Twisted Member
                  19,092
                  5347
                  Mar 11, 2011
                  Arizona
                  View My Photos
                  Local Time:
                  1:08 AM
                  I have thrown a big piece of clear plastic over a vehicle and stuck one of those little electric room heaters under there with me before when it was too cold to feel my fingers.
                  Just a thought.
                  • Like Like x 1
                  • Tyshiz
                    58
                    13
                    Aug 11, 2017
                    Vermont
                    View My Photos
                    Local Time:
                    3:08 AM
                    Oooooo ouch. My other dart i had was a slant. I was losing coolant. Now, i will admit i get ahead of myself. My brain doesnt always tick right. But i do have extensive knowledge... and i dont know why i would thought that changing the head gaskets and rad, would not cause an oil pressure loss. I thought i needed a motor rebuild.....bought new motor and installed..... the only problem with the old motor was i hadnt torqued correctly. So sometimes i overthink, sometimes i underthink, and sometimes i just dont know. Im glad you guys are all here to help :thumbsup::thankyou:
                  • Tyshiz
                    58
                    13
                    Aug 11, 2017
                    Vermont
                    View My Photos
                    Local Time:
                    3:08 AM
                    My landlord would kill me lol. I have to look like im just fiddling with something... cant have appearance of big undertaking.
                  • nm9stheham
                    nm9stheham Well-Known Member
                    9,765
                    2177
                    Dec 20, 2013
                    Waynesboro, VA
                    Local Time:
                    3:08 AM
                    I am glad to hear that, though not that you have to do it. But the leak looks to be coming from the back coolant hole past the used gasket.
                    The problem with the sequence of assembly is that the intake has to settle downward against both heads as it sets in. In the sequence done here, if the head bolts are torqued and the head locked in place and then the intake bolts tightened, they can't 'pull' the head upwards to seal the intake gasket. There might be some magic sequence of torquing the head bolts just a bit, and then torquing the intake bolts, and then going back to the head bolts, but getting that right is iffy.
                  • Tyshiz
                    58
                    13
                    Aug 11, 2017
                    Vermont
                    View My Photos
                    Local Time:
                    3:08 AM
                    Alright so whos comin to help???? Lol
                    • Like Like x 1
                    • nm9stheham
                      9,765
                      2177
                      Dec 20, 2013
                      Waynesboro, VA
                      Local Time:
                      3:08 AM
                      I'd be there but your state's letter after the 'V' are all wrong LOL
                      • Like Like x 1
                      • Tyshiz
                        58
                        13
                        Aug 11, 2017
                        Vermont
                        View My Photos
                        Local Time:
                        3:08 AM
                      • toolmanmike
                        toolmanmike FABO Staff Staff Member FABO Gold Member
                        34,050
                        15959
                        Jan 18, 2006
                        Iowa
                        View My Photos
                        Local Time:
                        2:08 AM
                        He's from Virginia and you are from Vermont
                        • Tyshiz
                          58
                          13
                          Aug 11, 2017
                          Vermont
                          View My Photos
                          Local Time:
                          3:08 AM
                          Gotcha hahahahaha yeah makes since now.
                          • Like Like x 1
