Help ID a tranny off of craigslist
hemitheus
19? Plymouth Scampenstein
Taylor, MI
So i got this transmission off of a guy on craigslist. He claims it is out of a 64 dart and is a 3 speed. The tranny was caked in grime 1/2' thick on the clean parts. but it was almost free. So i got it. Dont have a pressure washer so my saturday AM, scrapers, oven cleaner and a hose spent some quality time together. Its almost clean, the nuimbers i did acquire so far are C 13303 G and 8 24 77. What do those represent? is the 8 24 77 August the 24th 1977? If so I dont even know if this guy knew what he was talking about with the 64 dart thing. Also the shifter, which wasnt attached when i got it is a hurst shifter.
Help me id this tranny. Are there other niumbers I should be looking for?
dont let the pic fool you. it was filthy before. scraped off a pound and a half of grime.
any idea where on the bellhousing these numbers are? didnt see any when i was cleaning it. going to go look again
OD 4spd tranny would be AWESOME. especially since i bought it thinking it was a 3spd.
No, just trying to help you solve your dilemma, I wouldn't be surprised that's what you have.
it has nothing on the bell housing at all.
on the tail shaft is also has
:037
C-9953
ss3 (but the 3 is stamped and the rest is raised)
on the shift plate cover c135 50
no other markings except a pentastar and "ace co"
well I guess I should just finish cleaning it up and test the shift pattern
1 3
2 4 R
or
R 1 3
2 4
I found this: http://www.forabodiesonly.com/mopar/showthread.php?t=44853
Could they be stamped on the mating surface where the trans bolts to the housing?
Hey if nothing else I'm learning something, in between chasing the 2 two year old grandchildren around, LOL.
EDIT: I do find multiple sites that say the numbers are on the bell somewhere.
Find neutral. Then take a wrench on the front shift shaft (3/4) and turn it RIGHT (CW). That is 3rd gear on a 4 speed, OD gear on an OD gearbox. Then just turn the input shaft ONE turn and watch the output.
If the output turns LESS than one turn with the input, it's a 4 speed
If the output turns MORE than one turn with the output, it's an OD
Turning the shaft LEFT (CCW) will be 1:1, or straight through, on EITHER a 4 speed or OD.
looks like a b/e body 4 speed. note the 2 shifter pads. also looks like an aluminum case. def not 3 speed and not a '64. if it was a '64 it would have a ball and trunnion flanged tail shaft........just my 2 cents
man you guys all rock.... thanks.
I am pretty excited. OD in a slant. SWEET
Its a TRUCK transmission, they never put overdrives in B or E bodys, people see the dual shifter pad and assume B or E body, but thats how the truck transmissions look
^^^ thanks.
So if i were to use this in my 64 valiant id either need to custom fab a hump OR replace the tailshaft with one from an A833 from an a-body?
Hell, I wouldn't. The installed length of a long shaft A833 is the same as an A727 Torqueflite. I would think with the dual shifter mounts you should be able to fab / modify shifter arms if necessary. The mount/ crossmember should fit same as it does an A-727
Same length? I have a 904 but thats awesome. Will the auto yokes and ujoints be the same? and the mounts?
