RustyRatRod
Caput villa stultus
The housings are not cast iron. They are steel. Probably weigh 1K pounds if it was cast iron.
the problem is the first shop that did my rear end didnt cut off the ends they chopped each axle tube in half took off what they needed and welding it back together.
I had an old racer tel me they put -2 degrees negative into the rear end when they built it with a backing plate, supposed to track better? Dont know, guy smoked filterless Lucky strikes too. If it was warped, I would think a mandrel installed set of ends would cure just about any tweak. as long as they are parallel and perpendicular to the axle center line?
