do you think it's a problem that needs immediate fixing , re replacing cam and lifters , or is it possible that I can keep driving it without an issue ? When it starts cold the lifters make a lot of noise , as it warms up it gets less noisy , when warm no noise at all .
I plan on changing the heads this fall or winter , just wondering if I should push up the schedule . Don't want to have a bigger problem where I'l have to change pistons and redo the crank and rods .
Thanks
Thanks
