omahamoparguy
- Joined
- Feb 19, 2010
- Messages
- 756
- Reaction score
- 32
Late one night last week I was surfing over the Summit Racing web site in the wee hours (you know how it is, you lose track of time). I was looking over the 318 pistons and I noticed there was a piston that had a compression distance of 1.658. Now that is way low down there in a stock 318. Like 7:1 territory. It is a cast piston made by silvolite, $239 a set.
I got to thinking that the piston would be so low down there that maybe you could utilize a 360 stroke in the 318. Yep, sure can. Do the math youself. Even with a .015 shave off the deck you would still have about .014~ of deck clearance. But then I thought, well you still gotta turn down a 360 crank and that could get pricey. So. I scanned over to the ceankshaft section and sure enough, there was a cast 3.58 stroke crank with the 318 size of main journals, all for the price of $366 dollars. So I ran some compression ratio calc on the web and I came up with this.
The cubic inches with a .040 over bore would be 350~ and the compression ratio would be 9.6 approximately with a set of 360 heads with 72 cc chambers. I don't know how much of a cam this would accept cause the pistons a perfectly flat tops. Has anybody done this yet?
Anybody know how much abuse the silvolite pistons would take? If anything, sounds like a great motor for a truck.
