So I dropped a 360 into my Scamp, at the same time I installed a new idler arm and upper tie rod end.
The idler arm hits the bottom of the header and the tie rod end is so close the rubber boot in melting.
Any help would be much appreciated. The headers are Hooker Comp's. I will buy a new set of affordable headers if this will help. Can't afford TTI's right now.
