Is PS Pump Unique for 67 Dart?
timothy c
Active Member
huntington beach
I've been trying to find a new / rebuilt PS Pump for my 67 Dart, but no luck. Or should I say that they are not in stock and needs to be sent back to (?) to have it rebuilt. I've tried Summitt, Auto Zone, Classic Industries, O Reilly, and no luck. Any ideas?
Thanks
Tim
If I am not mistaken chrysler used two different P/S pumps for different years.
One with the round top filler neck on the reservoir was made by thompson, and the one with the egg shaped filler neck was a saginaw. Saginaw pumps and parts were more available when I was looking for parts for the thompson pump on my 65 coronet, so I had to get a rebuild kit and rebuild it myself.
I will post a link to a rebuilt pump from napa that i pulled up for a 67 dart maybe it is what you need. http://www.napaonline.com/Catalog/C...20+2020014+4020037+5999999&Ar=AND(P_RecType:A)
Hope that will help you out.
Matt
Thanks Matt...I'll check it out!
I will post a link to a rebuilt pump from napa that i pulled up for a 67 dart maybe it is what you need. http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?A=NSP816666_0186429439&An=599001+101967+50020+2020014+4020037+5999999&Ar=AND(P_RecType%3aA)
Matt
I have one on a 67 dart /6 car if your interested. Please PM me here.
Hope This Helps
Saginaw Pump
If You Have The TRW Pump Good Luck Finding A New One, ''YearOne'' Shows One For $200.00$ +, Weather Or Not It's Available Is A Different Issue.
And No Remanufactured Are Available From Parts Stores.
Found One On ''EBAY'' But Its In Okay Shape, Weather It's Good Or Not Idk, The Seller Says ''In Good Working Condition''. The Bid Is Starting At 10.00 With 20.15 Shipping And 4 Days Left As Of 1/25/2012, Here's The Link.
http://www.ebay.com/itm/60s-MOPAR-D...Parts_Accessories&vxp=mtr&hash=item27c2abae27
If The Link Doesnt Work For You Here's The Item # 170769755687
If You Dont Like The Way The Pump On Ebay Looks, I Believe I Have A TRW Pump That I Would Sell Let Me Know Via A Message. Good Luck
Also I Dont Know For 100% Sure But You Might Be Able To Switch To Federal Style Brackets And Use A Federal Pump.
My 67 has the TRW pump. I got a rebuild kit at advance auto parts and only took about 30 minutes to install it. Hardest part is getting the spring loaded vanes back into the pump chamber but wasn't too bad. If you pull it apart watch out for these they want to fly!
