Timmy's Toy
I am looking to clear up some misconceptions about the front cam plate on LA engines. Actually I don't think they're any different on Magnum's as well. On the oil galleys behind the cam plate is a freeze plug. I have heard that you should drill a very small hole in each plug to let oil out for the chain and you should drill a 3/8 hole in the plate to let this oil out through to the chain via the small hole you drilled. My machinist says to leave the plugs out completely and just butt the cam plate up and everything will be okay. I am having real concerns with that. What is the proper procedure here?
