LA - Cast cranks ( Dont throw away )
NCmtnDWELLER
Cartoogechaye - NC
Was reading some of my books this morning and found this interesting fact !
Yes, that has been related here many times by experienced folks. We used a stock 273 1968 cast crank in our 340 with a true 10:1 SCR and an estimated 375-400 peak HP, and a very torquey set-up.
Good to know I can normally find 318 engines very cheap have actually found running 5.2L (Non - Mangum engines for $150) .
I have a friend in Douglas NE that has two 318 engines one from military truck and another one from wrecker for like $ 200 each one even had the very thin balancer on it so could be steel crank also.
My guess is that with your gasser, these cast cranks may be marginal at best. With your HP and assuming you get it to hook up well, the shock and load on the crank is going to be a bunch higher than for a street car like outs. At least you have a very light chassis to work with in that Henry J.
I have a teen crank and a 273 (steel) crank. You never know when you may need one.
Yes sir - I own 2 factory steel cranks so going to run one of them but I have more respect for the cast cranks after reading said article.
Just got the top back last night that Yellow Rose gave me and it cleaned up well could not resist setting some 450s on top .
Most of the info in all of the Larry Shepard books is the same, and it's mostly copied from the older books and Mopar engine manuals. By the time they are published, most of the Mopar part numbers are discontinued.
There is a newer one from a different publishing company released in 2016, but has mostly the same info as the HP Books version, and most part numbers mentioned were were discontinued years ago. The book is even titled how to build Max Performance Mopar small-Block Engines, but somewhere half way through a paragraph says something to the effect of this book is NOT for building maximum performance engines. Thought that was funny.
Anyway, they are all good reads, and the part numbers are decent references if used parts come up for sale.
Oh, it has to specifically be a 318 crank? Not just any LA crank like for 360? I have a 360 crank.
Im sure any crank made by Chrysler !!!!
Not Daimler Chrysler is top quality
I seem to remember a man named
Joe Sherman who used to turn some Chebby 400 cast cranks well over 8000 rpm .
LOL but it seems I have acquired a few over the years! I am just a couple of states north of GA - SC, NC and then to the top of VA almost to WV LOL! I should take some of these to the Nationals but Dang they are heavy to lug around!
When is the nationals again ? Maybe we work something out ?
Thanks Chris.
