Apr 9, 2009 #1 mikedevore Well-Known Member Joined Jan 13, 2005 Messages 2,609 Reaction score 168 Location Oklahoma Can You Install A Non-lock Up Convertor In A Lock Up Trans. & Make It Work?
Apr 9, 2009 #2 M Max340 Well-Known Member Joined Sep 27, 2008 Messages 463 Reaction score 10 Location Pennsylvania No. The LU input shaft has an extra bit on the end which will not fit the non LU converter.
Apr 10, 2009 #3 mikedevore Well-Known Member Joined Jan 13, 2005 Messages 2,609 Reaction score 168 Location Oklahoma Can A Loch-up Trans Be Converted?
Apr 10, 2009 #4 D DJVCUDA Well-Known Member Joined May 26, 2004 Messages 1,075 Reaction score 35 yes - you need a new front pump & input shaft. you also have to modify the valve body to block off the lockup.
Apr 10, 2009 #5 mikedevore Well-Known Member Joined Jan 13, 2005 Messages 2,609 Reaction score 168 Location Oklahoma Thanks
