Looking for an anto od trans for a 66 /6 Valiant
Automatic? The 500 series overdrives out of 2 wheel drive Dakota Pick ups can fit with modifications and some wiring, switches and the like. Nothing is plug and play.
The only auto OD would be the either a LA 42RH or a Chevy (forget the nomenclature) BUT to mate either to a slant, an adapter would be needsd. For example a slant to LA, an adapter was used64 to 66. Over at slant6.org there was a group buy on the Chevy to slant adapter. I’m using a 42RH in my 65 Dart but it will be mated to a 273. There are other consideration to use one of those OD’s
The only auto OD would be the either a LA 42RH or a Chevy (forget the nomenclature) BUT to mate either to a slant, an adapter would be needsd. For example a slant to LA, an adapter was used64 to 66. Over at slant6.org there was a group buy on the Chevy to slant adapter. I’m using a 42RH in my 65 Dart but it will be mated to a 273. There are other consideration to used one of those OD’s
Dang, I forgot about the slant 6 having a different transmission. A 3 or 4 speed manual behind a slant might be an easier swap if the OP has a manual.
If you're looking for a bolt-in answer, it ain't happening.
The Mopar and GM overdrives will both require adapters or bellhousing surgery and replacement, both will require crossmember mods of varying degrees, and they'll both need modified or custom linkage and specific wiring to those transmissions. RH series Mopar ODs can be run stand-alone, RE series will require either a controller or a set of toggle switches wired in for controlling the functions. Mopar units will require floor pan/tunnel/crossmember mods, the GM will require a custom speedo cable, and *possibly* some tunnel mods in the tight confines of an early A tunnel.. Both will require a new custom driveshaft and a custom transmission mount.
Probably your best bet and the least amount of work would be a Gear Vendor's overdrive unit mounted to your existing 904. It will still require a new driveshaft and speedo cable, and POSSIBLY some tunnel mods, but still the least amount of work.
Dodge 3-Speed Auto - Gearvendors
Even the RH/ RE Mopar ones require extensive rear crossmember surgery and may require a bit of floor pan mod
The only other option I know of MIGHT be a "Gear Venders" which is made to bolt in place of SOME Mopar tail housings. You will have to research that. So for that you'd need a factory Mopar auto and YOU MAY need to update it to a later model to fit the gear venders, don't know. IN ADDITION the early cars had small snouts on the torque converters meaning the pilot hole in the crank is also small.
I would ditch the idea. People drove slant powered cars for decades with no OD
The short answer is nothing. Nothing is a bolt in and nothing will fit without major floor tunnel surgery and cross member surgery. You might check with the guys at Gill Welding to see if they offer some kind of adapter plate. They are Mopar and slant 6 guys. That would be my first step. Getting "whatever" transmission I chose to bolt to the engine. From there, it's all pretty much labor.
If you currently have an automatic, you already have a 904.
If you don't have any transmission at all, beware of issues using a '68 and later 904- the convertor nose is larger diameter than the '67 and earlier units and they won't fit your '66 crank flange.
What are you trying to achieve?
I mean there are a few reasons for wanting to do this kind of swap, and some of them do not require an overdrive.
As for myself for example;
If I wanted a lower cruize rpm and also did not want the manual-trans any more, But I didn't want to lose first gear take-off power, here is something I would consider:
Overdrive ratios usually come in at around .69 to .78; which is an average of ~.74. Lets say that your rear gear is a 2.94, and your tires are 24" tall. This would make your cruise rpm to be, 65= 2680. Thus, with overdrive, your rpm will be reduced to; 2680 x .74=1980.. With an A500, actually to 1849rpm
So the next question is; will your /6 pull that? and the answer is, a 225 might, but probably a 170 will not. This means that you will need to change your rear gear up, until the slanty can pull it. The point is that to pull the A500 at 65mph, you will likely HAVE to change the rear gear as well.
>and the next question is; what will happen to your take-off performance.
Well, your A903trans probably has ratios of 3.22-1.84-1.00 so the starter is
3.22x2.94=9.46... But with the A904 auto, the ratios are 2.45-1.45-1.00, so the starter will be 2.45x2.94=7.20 but your convertor might give you 1.6 to 1.8 back, so
7.2x1.7= 12.24 which is 29.4% better than the 9.46 of the A903. Which means, that you can swap out the 2.94 gear for 29.4 less gear and be no worse off, at the starting line.
Ok then 2.94/1.294= 2.27 gears.
But there is nothing like that in the early-Mopar line up. Well maybe 2.20s but good luck finding one of those.
But there is a 2.76, and maybe you can find a 2.45 from a later model car.
Let's say you consider a 2.76. Your new cruise rpm is 65=2510 at zero-slip,(say 2590 at 3% slip.) and say you score an A999 LU. the ratios are 2.74-1.54-1.00 and it has a Loc-Up, so your cruise rpm is 2510., your starter gear will be, 2.76x2.74x~1.7=12.86 still 36% better than with the A903. This indicates that you can give up yet more rear gear.
>Let's say you score a 2.45 rear, and still the A999LU. Your new cruise-rpm is 65= 2230, and the starter is 2.45x2.74x1.7=11.41; still ~21% better than the A903.
So now, what about Second gear?
>Currently with the A903 and the assumed to be 2.94s, the ratio is 2.94x1.84=5.41
With the A999, the ratios would be 2.45x1.54x ~1.3 in the convertor =4.90..... so, Second took a bit of a hit, about 9%. But-um First gear got plus 21%, so here's an idea,
>lets swap in an A998LU instead. the ratios are same as the A904, so 2.45-1.45-1.00, and lets go back to the 2.76s. The new roadgears are ;
11.49-5.20-2.76 compared to the current
9.46-5.42-2.94 See, there you go,
21% better first gear, about same second gear, 6% better hiway cruising.
The point is, that yes an overdrive would be the cat's meow, but depending on your current rear gear (I assumed it was a 2.94), you can make other combo's work, until the cruise-rpm gets too low for your slanty to maintain speed while cruising.
>>But, if you're looking for fuel economy. Firstly, every 1% reduction in cruise rpm is said to produce a corresponding increase of just a half a percent in fuel-economy. So then going from 65= 2680, to 65=2510, is a drop of 167 rpm, which is 6.25 percent, producing a savings of 3.1% fuel economy. If your current combo is doing 20mpg, then you are looking at .624 mpg increase to 20.6mpg. You'll never get your money back from the above swap, nor, more likely, from any gearing swap.
Now, getting back to what would I do?
For fuel economy with no loss in performance,
Hands down I would put a V8 into it with 2.20 gears, for 65= 2000. a drop of 853rpm, or 31.8%, and an economy increase thus of 15.9% from say 20 to 23mpg. Now that's a difference that counts. Sure first gear with an A999 is gonna be an abysmal, (that's a joke), 10.25 compared to 9.46 of the A903/2.94 combo, but criminy Ima putting a 2800LU in it, and we are gonna burn rubber!
If I'm going to this trouble for fuel economy, Ima gonna install a lo-po 273 bumped up to hi-compression, with a 4bbl. But more likely I'll be installing any old 318 with a "factory" stall LU; probably around 2400.
This swap is not complicated at all, but does require some forethought, and time to collect the parts, and a bit of cash. But the end-result is so worth it! I once did this with a hi-compression 340 bottom end, a factory 318 top-end, a 318 hydraulic cam, and a 2bbl!. In a 65 Valiant wagon, it was a torque beast, and was so easy on gas....... back in 1974 or so.
>In your case, since your car already has a clutch in it, I would just install an A833 overdrive. The ratios are
3.09-1.67-1.00-.73 od compared to your A903 at
3.22-1.84-1.00. The rpm drops from 65=2680 to 2072, a drop of 608rpm or 22.7%, for an economy increase of 11.35%, or from 20mpg to 22.7. This is a really good gain for low dollars. This is a win-win, almost zero loss swap. Almost zero, cuz it ain't an automatic, lol, and it will cost you a driveshaft-conversion to a slip-yoke; but the rear gears can stay. I have noticed that the od boxes are rising in purchase-price, so get one asap. I used to buy these at swap meets, late in the afternoon, for $50. But I guess those days are gone. You will need the matching BH/fork/etcetera, and a 4-speed floor-shifter.
Thank you everybody !!! guess i'm looking for a 904 now lol
A nice bolt in would be the A999 version of the 904. It's not an overdrive, but it does offer a lockup converter. As far as I know, there was no A999 for the slant 6 so you would still need an adapter.
and they (generally) have a lower first & second gear so you can run a more highway friendly rear gear without sacrificing too much giddy up on the street.
a reasonably half step to lowering the R's at cruise without cutting up a car and spending a grip of dough.
Plus, I believe the guts from an A999 will transfer over to a slant 6 904 case.
There was a means to put a SB trans on a/6. But hard to find these days.
Back in the 60s there were some /6s with a 727, mostly trucks. Before they came out with a /6 specific case for the 727 there was a cast iron adapter that bolted to the block and the trans then bolted to the adapter. Along with a spacer ring to space the flex plate back the same Amount.
I bought a complete 64 motor and trans solely for that adapter setup a while back.... The seller wouldn't seperate. No I'm not selling. I have a use for it out in the garage as soon as I get around to going thru the a500 that's under the bench
I would have to go back to my notes, but I think everything from the A-999 will transfer to the 904 case except for the double wrap rear band (there is no anchor for the band in the 904 case). If I remember correctly the A-998 parts will transfer over to the 904. There was a 904T that was used in some trucks, but I don't know what parts are different.
I think the 904T had an extra disc and steel plate in each clutch pack vs a non "T"
I know for sure, that the A998(non-LU) slanty geartrain stuff, transfers into a V8 A904 just fine. I just re-used the VB from the A904, cuz the cases are different and it looked to me like the VBs might not swap successfully, altho they will bolt on. .
But I learned that, you cannot mix planetaries between output shafts, between them. There is a before and after year, where the shape of the splines changed, and if you mix planetaries around, you will lose the planetary splines out of the aluminum hub, in less than 20 miles. The spline count is the same and the planetaries will physically swap over. But the shape of the splines is different, as if cut by different machines.
and so help me I tried to see the difference but could not. After having towed the car home, I swapped the back end straight from another core, and it never happened again.
I had wanted the 4-planet aluminum units from the V8/904 and never even considered there was an output shaft difference. Lesson learned
