Looking for wheel alignment specs for 1975 Dodge dart.
Ricer
Member
Canada
1975 dodge dart with new PST tubular upper control arms. Looking for alignment specs.
Thanks in advance
Man, ain't that Sexy! Looking Good! Check for the "skosh" chart sticky here. Definitely Don't want the factory specs. Unless you are using Bias Plys...Depending on what you Want to do with the car, around 1/8" toe in, as much+ caster as you can get, and around 1 to 1.5% camber. Please double check me. . But that should be close... my issue is, I cain't find anyone in the entirety of Tampa Bay to do it!
Yup, if you’re using radials use the SKOSH chart. It’s pretty spot on in its description, I think it’s still conservative on caster though. I’d say you can add +1.5* of caster to its recommendations across the board.
Tell your alignment guy to put as much caster into it as it will allow as long as the spread is right. If you have manual steering use the chart specs.
