The bolts up front by the water outlets on the heads tend to corrode. I have reused all the magmun intake boltson jobs I have done. They are not torque to yield.
Yer just too strong, Del. LOL
Fo be honest ,Del.... Every unknown fastener,I have dealt with: Remove with hand tools, cautioned... I made the mistake on a Pontiac 455 long block, patience is the key, here... Soak it with penetration oil, hit some flame old school torch, in intervals.. The penetrating, heating cycled, will get those bastards loose ,Del....I admit the FIRST one I broke was with the impact. Just never entered my mind. The OTHER two I was try'n to break them loose with 3/8 drive ratchet. Broke 'em right off. Reminded me of the old OEM bolts on the ol 62 Landcruiser FJ-40. I think every bolt on that thing was grade . (POINT) 5, er 1/2 er something. Lord they were soft
Got pics?
.............OK,...........how do you explain that since 1970 when I owned my first Mopar, I have NEVER broken an LA manifold bolt? Makes me wonder if these aren't susceptible to corrosion due to material or poor heat treating, etc. N' yeh, in my non-rocket-scienceness, I DO realize these are 5/16 and not 3/8Holy crap this ain't rocket science. First of all the intake bolts are just plain Jane 5/16" x 18 bolts NOT TTY. The outer 4 bolts (aerial view) corrode because they are not blind holes and are exposed to the elements from the top AND the bottom. All 8 inner bolts are open into the engine so they get splashed with oil and are bathed in engine oil vapors their entire life so they don't tend to corrode. J.Rob
I just ran into this today. Both front intake bolts snapped. I am soaking and applying heat. I have another magnum and the bolts came out fine but it was a 92 dakota and this one came out of a 98 jeep so it probably got its fair share of water splash.I haven't worked on a gob of Magnums, but have done a few and never seen this.
