.............Wicked... have u figured out a price yet...........kim........
I am also going to make a set with just straight arms and factory style bushings that will be cheap. Over the next couple of days I will make those jigs.
Is it possible to do a straight arm with rod ends instead of the standard bushings? Might be nice for those of us that need the extra alignment adjustment without having to go offset bushings.
I dont know if it was stated before, but will these accept stock mopar ball joints? I see that you are also using 5204 coil overs and a 400 pound spring I believe. I know that you stated that you can use J bars which I have and I also have the inner fender brace. But I was wondering is the triangulated coil brace best along with the J bars? Or what is the optimal setup? And you feel that these are all good for a 1/2 street 1/2 track car right? Thanks John Appreciate all your work and time you take to answer my questions and others.
will you be at chrysler carlisle?
This may be a dumb question, but what type of steel are these built from?
just my humble 2 cents... but since your lowers have a "curve" design to them maybe you should try that with the uppers to make it like a "set" if that makes sense!
