which mechanical fuel pump is the best pump between the edelbrock performer rpm part number 1720 and the Holley pump part number 12-360-11 or the Quick Fuel 30-360.
All 3 pumps say 110 gph the edelbrock is the most expensive at 150 and the Holley is 135 and the Quick fuel is 127.50.
This would be going on a 300hp crate 360 magnum with a Quick fuel super street series 680cfm carb.
Running in a 91 half ton short bed 4wd pick up.
I have a cheap parts house replacement pump on it right now from oreilly auto parts I believe it's a prescsion pump, it doesn't hold a steady pressure sometimes it's at 6.5 psi sometimes it's down 3 psi and it just doesn't seem very consistent.
Maybe that's just the gauge on my fuel line though?
AnywYs I was just thinking it would be a little more consistent and run a little better with a higher quality pump on it.
