RAMM
Thanks it worked really well and I still have it. J.RobI love that windage tray. Spanky!!
I'm on page 8 of this train wreck for some reason and a 5.9 Magnum is the EASY button for this fella. If we're gonna help him this is what needs to be harped upon. J.RobYeah. A 5.9 magnum.
$$And a sonic test would be a good idea in general. A lot of 318 blocks get thin at .060 over. The ‘73 318 blocks I have seen were better than most in wall thickness, but you don’t know until testing is done.
i have those kb399 domed pistons for my own 318 build too, mainly as i'm using 2.02 'j' heads which wouldn't help the already low compression with stock pistons.Question on the parts, again. Did main caps for the white block come with it? And what brand are those rods? They look like good pieces. Being that this is all custom work, it’s possible the previous builder has ground the big ends of the rods to .925 width from .940 (.0075/side) and had the big ends honed out for 2.1 to 2.125 bearings (.0125 per side) which would allow using LA Mopar rod bearings after dressing the tang registers depth back in. It would be worth measuring them with the dial calipers to see if they have been modified in that manner. I don’t hate the idea of your using parts for a drag only kind of build, but I would want to sonic check the cylinder thickness above the cement. If you wanted to put an all Chrysler rotating assembly in, then here are your pistons for high compression with enough valve pocket for whatever cam you decide on.
KB KB399KTM.060 KB Performance Hyper Piston and Ring Kits | Summit Racing
I agree no need to reinvent the wheel here.This thread is utterly fuckin ridiculous. Offset grinding or cutting a cast 360 crank to fit 318/340 mains and Chevy rods to make 350 cubic inches is like having plastic surgery to have 1” added to your dick to make it 4” long. The best advice you’ve been given already is sell off all that garbage and move on. What does a custom 350 cu in stroker with all custom parts do that a 360 doesn’t? Answer, NOTHING. Stop bullshitting yourself and put a proper plan together that doesn’t involve someone else’s science experiment gone wrong. Go get a 360 block and put a 4” crank in it. I don’t care if it’s magnum or LA. You'll be WAY ahead in power, performance, and reliability. And you won’t have to have any custom made parts or really do any special engine building tricks because the kits are layed out for you. Holy **** this is dumb.
100%! He'll never agree, because someone's told him different and he's latched onto it. A true steel trap. lolThis thread is utterly fuckin ridiculous. Offset grinding or cutting a cast 360 crank to fit 318/340 mains and Chevy rods to make 350 cubic inches is like having plastic surgery to have 1” added to your dick to make it 4” long. The best advice you’ve been given already is sell off all that garbage and move on. What does a custom 350 cu in stroker with all custom parts do that a 360 doesn’t? Answer, NOTHING. Stop bullshitting yourself and put a proper plan together that doesn’t involve someone else’s science experiment gone wrong. Go get a 360 block and put a 4” crank in it. I don’t care if it’s magnum or LA. You'll be WAY ahead in power, performance, and reliability. And you won’t have to have any custom made parts or really do any special engine building tricks because the kits are layed out for you. Holy **** this is dumb.
No and it's not dumb. Anyone who thinks that this post is dumb. Is full of pride. Some of us aren't pro's like yourself. You know what some of us who are still novice builders will turn into pro's someday. I am sure all you were novice builders at one time or another before you came pro's.This thread is utterly fuckin ridiculous. Offset grinding or cutting a cast 360 crank to fit 318/340 mains and Chevy rods to make 350 cubic inches is like having plastic surgery to have 1” added to your dick to make it 4” long. The best advice you’ve been given already is sell off all that garbage and move on. What does a custom 350 cu in stroker with all custom parts do that a 360 doesn’t? Answer, NOTHING. Stop bullshitting yourself and put a proper plan together that doesn’t involve someone else’s science experiment gone wrong. Go get a 360 block and put a 4” crank in it. I don’t care if it’s magnum or LA. You'll be WAY ahead in power, performance, and reliability. And you won’t have to have any custom made parts or really do any special engine building tricks because the kits are layed out for you. Holy **** this is dumb.
I’m not a pro, I’m a backyard hack at best. And you’re wrong. It’s dumb. You’re stepping over dollars to pick up dimes.No and it's not dumb. Anyone who thinks that this post is dumb. Is full of pride. Someone is aren't pro's like yourself.
...to pick up dog poop is more appropriate.I’m not a pro, I’m a backyard hack at best. And you’re wrong. It’s dumb. You’re stepping over dollars to pick up dimes.
No it's not wrong. You sure sound like a pro engine builder coming at me like you're pro. You know what we all start from the bottom as novice builders and learn from our mistakes into doing better. You know what I have no clue what the last owner all had into that 318 engine except for the LAST OWNER had Chevrolet small block connecting rods and Chevrolet pistons in it. The man was in his mid 70's so yeah he was old school and had ways he built his engines I am sure. So many of you coming at me like I am the one who built the engine need to understand something. I DIDN'T BUILD THE ENGINE, I BOUGHT THE ENGINE FROM THE VERY KIND GENTLEMAN. I bought the engine because I was going to buy it for a build myself. I didn't have a clue he had filler concrete mix in it until I was wondering why it weighed more than my 87 318 which is a standard block with nothing in it. After picking many brains on Facebook in what it was used for made sense in why the last owner did what he did. I am going to build it for drag racing with nothing but Mopar parts in it, with or without any of yall's help.I’m not a pro, I’m a backyard hack at best. And you’re wrong. It’s dumb. You’re stepping over dollars to pick up dimes.
Yes, we all started at the bottom as ignorant novices. You're being an ignorant *** refusing to listen to good advice. That's your choice. Most of us learned it the hard way tearing stuff up. We're trying to keep you from doing that, but maybe you need to.No it's not wrong. You sure sound like a pro engine builder coming at me like you're pro. You know what we all start from the bottom as novice builders and learn from our mistakes into doing better.
not true. i was born dick first with a torque wrench in my hand and double stack snap on box attached to my umbilical cord.I am sure all you were novice builders at one time or another before you came pro's.
Yeah and all that fell on your head soon as you cleared your mom's hooha.not true. i was born dick first with a torque wrench in my hand and double stack snap on box attached to my umbilical cord.
look, we don't talk about that part alright?Yeah and all that fell on your head soon as you cleared your mom's hooha.
The question you need to seriously ask yourself is this. "Could these old, experienced assholes be right?" That's the sixty four dollar question. That's a reference I'm sure you're way too young to understand.No it's not wrong. You sure sound like a pro engine builder coming at me like you're pro. You know what we all start from the bottom as novice builders and learn from our mistakes into doing better. You know what I have no clue what the last owner all had into that 318 engine except for the LAST OWNER had Chevrolet small block connecting rods and Chevrolet pistons in it. The man was in his mid 70's so yeah he was old school and had ways he built his engines I am sure. So many of you coming at me like I am the one who built the engine need to understand something. I DIDN'T BUILD THE ENGINE, I BOUGHT THE ENGINE FROM THE VERY KIND GENTLEMAN. I bought the engine because I was going to buy it for a build myself. I didn't have a clue he had filler concrete mix in it until I was wondering why it weighed more than my 87 318 which is a standard block with nothing in it. After picking many brains on Facebook in what it was used for made sense in why the last owner did what he did. I am going to build it for drag racing with nothing but Mopar parts in it, with or without any of yall's help.
lollook, we don't talk about that part alright?
Yep and guess what I got smart found Mopar parts for 318 that were reasonable price instead of using Chevrolet parts.Yes, we all started at the bottom as ignorant novices. You're being an ignorant *** refusing to listen to good advice. That's your choice. Most of us learned it the hard way tearing stuff up. We're trying to keep you from doing that, but maybe you need to.
You can keep saying it and try to convince yourself that you’re right, and while I applaud you for being hardheaded, because I am too, you’re still wrong. There is a reason no one does this crap anymore. Because there is much better stuff available in the aftermarket for much less money and much less effort. Back in the glidden pro stock days they did stuff like this because they had no options. You have better options and all we’re trying to do is get you to see that. Sometimes honesty is harsh. We’re being honest.No it's not wrong. You sure sound like a pro engine builder coming at me like you're pro. You know what we all start from the bottom as novice builders and learn from our mistakes into doing better.
Well I did some digging, found some aftermarket parts that will work for what I need that are Mopar and not Chevrolet.You can keep saying it and try to convince yourself that you’re right, and while I applaud you for being hardheaded, because I am too, you’re still wrong. There is a reason no one does this crap anymore. Because there is much better stuff available in the aftermarket for much less money and much less effort. Back in the glidden pro stock days they did stuff like this because they had no options. You have better options and all we’re trying to do is get you to see that. Sometimes honesty is harsh. We’re being honest.
