If you looking to build 375 hp engine they'll be fine.
makes no since to have all thone extra cubes and then put those plug heads on top so it can't breathe..obviously it will run fine and make great torque but man I'd hate to leave all that hp on side. If money is a concern I'd understand
Then, yes, it will work fine and be fun. All the other comments are correct, but if you just want a torque motor, it will be that!Money is relevant. I am a 66 year old disabled combat veteran on a fixed income. Big HP numbers are not what I am after. High torque numbers is fine with me.Just having fun.
Sure,you will make a whole bunch of torque,the engine will respond real good and you will be able to destroy tires at will i cant see anything being not ok with thatWill stock 72 J heads be ok on mild 418 stroker?
Sure,you will make a whole bunch of torque,the engine will respond real good and you will be able to destroy tires at will i cant see anything being not ok with that![]()
From what I understand that you want a 268 from comp or voodoo but you could go 275 if you want a little more.
I was looking at the Comp 268 but was wondering if it would work good with my combination. I have AC and power steering too. I have GM 200r overdrive trans with 4.10 gears.
Nothing wrong with your plan. You'll have the power and torque of a stock 440 in a smaller package.
