stroked340
Here's one for you............
If there is no damage to the cylinder walls, why not just pull pistons out, leave the rings on, clean everything thoroughly, put pistons and rings back in, with out a hone job. No reason why you can't.
True..but its all apart so it's getting done..just the way I like to do things..
