SRT_DSTRHOLC
"There is never enough horsepower...."
How do I do this? I want to put the weight of the calipers to the center of the car, but I also want to be able to bleed the brakes haha Please help any info welcome!
Complete left spindle and all other parts excluding the ball joint installed on the right. Right on the left. Then locate longer brake hoses. There is more than one thread that gives more details in you use the search. I have seen the brake hose part number and application they are using in other threads.
If you swap spindles only the bleeder will be on the bottom of the caliper.
Thanks so all parts sep for the ball joint switch sides..Thank you.
and longer break hoses I will have to find those damn part numbers since I bought some already![]()
When I did my 68 Barracuda, I made sure to swap the spindles and calipers as described. Use some Volare hoses, remove the metal bracket that they have on them, and bolt them on. As you can see, there is plenty of play. Only down side, you may have to grind the end of the ball joint bolts or the stops on the lower ball joint to keep from losing your steering radius.
I would find something else to do than swap spindles side to side to gain some weight distribution. It's pretty insignificant.
The main reason I switched mine from the front to the rear was to gain clearance on my sway bar link. They would hit upon turning the steering wheel.
In the pic above that line enters the top so the bleeder ( not shown ) is at the bottom. To free bleed those calipers completely you would need to lay them upside down on top the spindle.
To completely bleed them any other way would never happen.
To switch the calipers from there original or OEM location will make the original limes too short and subject to stretch. I have very slowly and carefully rebent the metal part of the original lines so they dont get stretched but ... keeping that line off the inside of a 14 inch wheel is tricky too.
