My 416 stoker motor......
SBDart
Indy
Well i would like to thank mike @ mrl for all his help in helping me put together a very sweet 416 stoker motor.
THANK YOU MIKE.............
And to Gray @ Zimmerman bros motorsports for all the machine shop work.
Now here is the good stuff
70 340 block .030 over
Align hone mains
burnish lifter bore
and all the good stuff the machine shop does.
Scat I beam rods
Scat 9000 340 4" crank
KB 25cc dish pistons 340/360w/4.00" stroke w/ rings
Balance rotating assembly
SBM double roller timing set
deck the head surfsce ........ RHS X Indy heads
1.92/1.1.625 valves
Lunati voodoo cam.242 / 252 or .533 /.552
some small port work done
Super Victor intake
Biggs stage 5 750 DB
Hooker comp headers
PRM Stainlee steel rocker kit 1.5 ratio
One more time thanks mike for all your hard work.
no its just seating up stairs still need some more parts to put it together.
mike said that it should make 480/500 HP
Sooooooooooooo mike an estimate on the HP ON THIS SET UP?????
Not sure on the HP, but your combo is VERY similar to mine (except mine has Edelbrock heads and my cam is slightly bigger @ 248/254 duration). My car ran in the 6.90's all summer at Lucas Oil Racway Park (the old IRP).
I would estimate that my motor is in the 520-530hp range....yours should be close to 500hp. Bring it to the track in the spring and see what she does.
Your welcome. But the estimate was 480-500TQ.
Those numbers should be cake!
Think about this boys and girls: The right weight/converter/gear/hook and it will sneek into the 10's...all the while very streetable!
Get to wrenchin' ! ! !
Ok this what i am going to do.. My son has been hammer'in on me to get the dakota done. we just need some few thinks to get her on the road . i have had this thing for about 5 years now an i keep putting thing's in front of it. so he hads beat on me so much i had to gave in.
So i am going to put my motor in this dakota it is a very sharp truck. it is a back half truck 4 link set up 12 point cage dana 60 now it had 3.73 gears in it but who knows i may put some what i call taller gears in it. i will have to but some new headers for it jegs sells them for $450.00. so i will get them in april when i get my bouns check. this thing should rock . wish me luck. the truck will take less time an money to do then the dart.
but i am not done with the dart it will get done sometime soon i hope.
I have a ton of money in this truck as you can see. so it need to be done . with my 416 stroker motor in it it shoud be a fun truck...
Well the truck is got now .. My boy parted it out to buy his a car.
so i got to put Augie in the dart today it just a muck up is need to do some more work so the engine will come out soon . here are some pics of it ..looks good. its got to come back out so it can go up to mike @ MRL to have some thinking checked out first and dyno. Had the wife out there helping me also..
you might want to check on the rules for having the fuel regulator mounted on the firewall..believe nhra does not like it there.
This car is a street ride .... Not buliding it for the track.. be there and done that.. so much work ...
Where did you get those valve covers?
I got mine from hughes for $ 50.00 @ the indy swap meet a year ago and bought the mopar decals. and jegs wants how much for them !!!!!!!!! Almost 400.00 bucks for them don't thing so......
