Space Duster
Watching this one.
700r4 transmission mount. I saw an energy suspension one at autozone that looked like it'd work so I went on eBay and bought a rubber one for like $12 shipped, had to elongate the one hole in the transmission a little and it bolted right up. Should have it all bolted in Monday night and have the car off the ramps and jack stands and back on her wheels!!!The exhaust pipe on the right side of the pic there is bolted to the header and I did have the drivers side bolted up as well, all clears with plenty of room.One area of concern I have is your cross member clearance for your exhaust. This was an oversight when I built my car and didn't know if you had a plan yet cause it's really going to hang low......
Sounds good...just making sure you thought it all out...I really think I would spray a matte clear over the body and call it a day, I like the patina.The exhaust pipe on the right side of the pic there is bolted to the header and I did have the drivers side bolted up as well, all clears with plenty of room.
Eventually tho I think I'm gonna run TTI shorties, oval tubing exhaust and either an AAR-T/A style dynomax muffler or a spin tech muffler and side exhaust, all tucked up tight so I can slam the car and the exhaust/headers won't be the first thing to hit
I also did a wiring mod that slantsixdan recommended, ran 2 10 gauge wires with 50 amp fuses at each end from the alternator to the + post on the starter relay. Don't worry, the yellow yip ties are temporary.
You can run a bigger alternator and it bypasses all the smaller factory wiring. Also goes straight to the battery instead of going through the bulkhead connector, ammeter and other splices/connections under the dash.I'm not familiar with the advantage of doing this Modification.
