:king:it's getting there.for the nitrous i only have the arming switch and the trigger to hook up.the trigger i think it will go under the gas pedal.for full throttle activation....and hooked up the light on fuel pressure gauge
thanks manVery cool build!!!
what kind ofheat range isthat? the 63s are a 12 i will use some 115 superstock fuel mixed in with the 91Mine,was a basic 3923 Autolite.Ran a whiff of Av-gas,to be safe.
on autolite website it said heat range123923 ,was the lowest option,I had.Autolites are easy to understand.What are you,referring as 12?
