j par
Well-hung Member
Simply following all the instructions closely nothing more...adjust it properly?
Meaning the band adjustments and pressure adjustments...
if I just pull the VB and install the kit, I have to adjust the bands and pressures ?Simply following all the instructions closely nothing more...
Yup, easy... 3 screws for the filter and 10 screws for the valve body after you take out the shifter. The rear band is easily reached after the valve body is out and easily adjustable and the front band is adjustable from the outside of the transmission that's easy as well. The pressure adjustment is on the side of the valve body and it's an easy adjustment like flush or something like that... It's read twice adjust once lol...if I just pull the VB and install the kit, I have to adjust the bands and pressures ?
and all what they want a person to adjust is in the directions of the kit ?Yup, easy... 3 screws for the filter and 10 screws for the valve body after you take out the shifter. The rear band is easily reached after the valve body is out and easily adjustable and the front band is adjustable from the outside of the transmission that's easy as well. The pressure adjustment is on the side of the valve body and it's an easy adjustment like flush or something like that... It's read twice adjust once lol...
Yup.. follow the instructions and you'll be happy... For that matter a rebuild kit is only $120 and easier than falling out of bed....and all what they want a person to adjust is in the directions of the kit ?
You can even make a YouTube video of it LOL...and all what they want a person to adjust is in the directions of the kit ?
help needed with 904and all what they want a person to adjust is in the directions of the kit ?
OP doesn't need an overdrive.Right now plan is to leave the 904 in the car as well. Pull it, get it rebuild with some new and stronger innards but use it. Currently I do not want to cut the floor up for OD trans. The interior of my car is MINT and I really dont want to take it out. Also I dont do much driving long distance over 60MPH.
So screaming 3.55s are outI would like to have some fun when I am on the street in town and still be able to take the car at 65mph with out having screaming RPMs.
CorrectThe Op said a lot of stuff but mostly he said he's in the planning stages I'm looking for ideas. The great part about the Forum everybody has their own idea and you can grab them all and formulate your own..
Do you need a mounting bracket for this?You could stroke the 318 and go with a GM 200R4 auto. Nice over drive and you don't have to cut the car to pieces or buy expensive transmission control. That would leave you with the "numbers matching" engine......you did mention that as if it might be a little important.
i thought i read where you mentioned this in another thread and there was something else that needed to be fabricated.
OD is not out of the realm yet. Just making the hard choice on the 318 or the 360.
I really need to talk to a builder LOL
u do not need an engine builder to stick a take out 360 magnum with it's efi in
mabey an wireing guy
If you have a mind to;desktop dyno 408,single plane intake. 10:1 edelbrocks (IE.249 cfm @ 0.500", 28".) small tubes
Hughes HE2430AL cam:
HP = 401 @ 5,500 RPM
TQ = 427 @ 4,000 RPM
It looks like the HE2430AL would be the Torque cam, and when simulated with the Dual Plane intake, Peak Power and Torque did not change very much, but the torque curve was increased and flatter from idle to max torque.
I think you would know that better than I.how much would the .008 affect your calcs?
