Mystery Pistons help ID
dwire67
Seaford, Delaware
here is what I know
4.040 bore
.984 wrist pin
1/16 1/16 3/16 rings
compression height around 1.50
I thought these where for stock stroke 360 3.58
but with that size C/H they seem they are for 4.00 stroke?
have no idea who made them only markings are F/T with a lighting bolt cast in underside
They sure have one big dome?
Any idea's?
Unless they are not Mopar , what else would have .984 pin size?
I picked them up some where and was told they where 360 .030 over and they are really .040 over ...Speed pro ? could be
I thought they might be 340 pistons, but the C/H is wrong -340's 3.31 stroke and would have 1.80 or higher C/H
1.50 from the Center of the pin to the flat part of the piston?
a standard bore 340 or a +.040" 360, with a 4" crank. nascar did not use a 4" crank. looks old school, could be ForgedTrue
measure from top of pin hole to flat part of piston and add 1/2 the wrist pin diameter
I checked out some pictures of Forged true pistons and you hit it right on, from what I can tell they are Forged True , now I just have to get the right C/H
