OK, guys, here is the latest. First checked the carb choke setting again, with one full pedal, the choke completely sets closed, with approx 1/8" gap at butterfly. So to eliminate possible too closed I opened it an additional 1/8". then crank & gas 3 times before it would stay running. It slowly increased in rpms from 900 to 1400 in a couple of minutes, no missing just the shaking, opened butterfly with finger, did not like that, so left it closed until warm. after a few more minutes, hit the gas, idles a little rough at 850, but nothing bad. Then rpm it to 4000 no problem, smooth and good. I think the pulloff is working, I think the "new" carb may be the issue also, just do not know where else to look for it. When I had it apart, I adjusted all settings as per the rebuild kit, float, float drop, acc pump. the idle screws however have to be 2 1/2 full turns out to be fairly smooth. To Bill Grissom, when I adj the rockers, they obviously do have the ball/cup pushrod end, so are these rods all from the solid cam assm ?
