Need help with front suspension rebuild
Andre68
San Diego
Well I need to rebuild the front suspension on my 68 dart. I've been googling front suspension kits and I cant really seem to find one, and the one that I did said for drum bakes, but I have discs up front.
If anyone can tell me where to get a front suspension rebuild kit that would be great. Not looking for anything crazy I simply want to renew my stock suspension.
Also I did by the service manual for the dart, hasn't come in yet. Im curious, did this car originally have springs in the front? Because all I see are control arms and shocks.
Is it a 73+ disc set up, BBP or the KH small bolt. The difference in disc/drum on 67-72 cars is the lower ball joint hole for mounting to your spindle are larger on disc vehicle. If you find a set of drum LBJ's you can ream them to disc bolt sizing.
Sometimes looking at rockauto or even amazon can get you a kit at a good price buying individual parts.
Here's a list of moog part numbers from BBD
http://www.bigblockdart.com/techpages/moognumbers.shtml
All these cars have torsion bars, the long bars which run parallel to the front frame members from the lower arms to the rear.
A service manual is a wise first step
Not sure about "kits" but this is a good read:
http://www.bigblockdart.com/techpages/techindex.shtml
You pretty much want
Upper ball joints
Lower ball joints
upper Arm bushings, and consider getting the Moog "offset" bushings which allow for more caster / camber adjustment
Lower control arm bushings
Strut rod bushings
If you have a sway bar, you'll need bushings for it
You may or may not need new dust boots for the T bars
On the steering linkage:
Check the pitman arm ball for wear, you may or may not need a new pitman arm
new idler arm
Check the tie rod ends, you may or may not need all 4 of them.
Lots of threads on here about alignment. If you are using radial tires, don't use the factory alignment specs, this is a good read. Pay attention to the "skosh" chart:
http://www.allpar.com/history/mopar/front-end-alignment.html
and some threads from this site
http://www.forabodiesonly.com/mopar/showthread.php?t=183214
http://www.forabodiesonly.com/mopar/showthread.php?t=140927
http://www.forabodiesonly.com/mopar/showthread.php?t=195810
http://www.forabodiesonly.com/mopar/showthread.php?t=226484
http://www.forabodiesonly.com/mopar/showthread.php?t=183607
http://www.forabodiesonly.com/mopar/showthread.php?t=231627
im sure I probably need a new pitman arm, I took it off the center link today and the bushing was done, and the weird thing is the crew from the joint turned when I tried to tighten the nut back on and the screw thing turned too, so I pushed it back into the center link a little more and then it stopped turning and I was able to tighten the nut on it. Don't know if that's okay or not.
If by "screw" you mean the tapered part of the stud, the only thing that keeps it from turning is "luck" as you tighten it down. Normally on new parts the nut will snug up "by hand" or you can give the center link a little smack with a mallet or 2x6, etc, to "seat" the tapered stud.
