need help
MXJacob
Member
michigan
how do you disconnect the steering coupler from a manual steering box, so i can take the steering column out? i have already removed the roll pin but i still can't slide it apart. what am i missing?
It's just stuck. Use a pry bar or thin, wide wrench to pry the coupler off the box. If you pull on the column you'll just pull the coupler apart.
I use a great big open end wrench between the coupler and box. Don't get to "horsey" with it
Thanks I'm going out to try that now. I'm sure i will have plenty of more questions being that it is my first project.
Of course spray WD40 or PB Blaster in the hole where the roll pin was and let it sit overnight. There are many small splines on the shaft so a little rust can lock it tight.
