PocketAces
I recently fired my 273 for the first time. The engine is difficult to start but starts best with the distributor set at approximately 60 degrees advance all in. Once running above idle speed, I can time it back to around 35-40 all in and it will keep running. But when it quits it's hard to get it started again.
I just checked the valve timing and found that the cam is 4 degrees advanced from spec. Spec is intake centerline at 108 degrees ATDC, but I'm measuring 104. Exhaust centerline should be 108 degrees BTDC, but I'm measuring 112.
From what I'm reading, 4 degrees advance should not be a problem, and might actually improve the bottom end. But I wanted to rule it out as a potential source for my hard starting.
Here's the build:
273 with stock heads
Isky E4 cam
9.6:1 static compression
factory AFB carb which was running good when removed 2.5 years ago.
pro comp distributor which was also running good when removed.
Here's the build:
Isky E4 cam
