Ok Suprise
Ok Suprise
Great you found the broadcast sheet and fortunately it's still very readable. A couple of things I see on the sheet.I GUESS THEM MICKEY MOUSES COULDNT EAT TO MUCH..... THANK YOU DISNEY LAND
Crisp shift into all 4 gears no play. Reverse lifts and unlocks perfect.Hubcaps are perfect all but 1 lug missing. All seatbelt retractable work. Console very good cond. dash pad perfect. All a/c intact, there is a diverter valve for heat appears a bypass direct to heater core was done but Is present. Points are waisted nothing left to file. Underside amazingly clean.....
There, I got all the info on one page. WOW!!! What a nice build sheet! At the bottom of this post is a link to my 273 build thread. Just for fun.Great stuff THANK YOU,,,,,,!
Yes righty loose lefty tightyWhich hubcaps do you have, if it is the mag type like mine I can probably find one for you. Does your car have left and right hand threads like mine or have they been changed.
Wow! That's what I call a build. Very nice work......ToolmanThere, I got all the info on one page. WOW!!! What a nice build sheet! At the bottom of this post is a link to my 273 build thread. Just for fun.
Yes those Are the exact ones but again suprise found it under the spare.Are these the caps you have. Are the lug nuts the 2 in ones and do you need left or right side. I am working the next 3 days, but will find you one Thursday.
There pretty long ones about 2 1/2 inches long singleYes those Are the exact ones but again suprise found it under the spare.
Think you misunderstood it was just a lug nut I was missingAre these the caps you have. Are the lug nuts the 2 in ones and do you need left or right side. I am working the next 3 days, but will find you one Thursday.
