pishta
I know I'm right....
put the little tube into the outlet hole and p-u-m-p while turning the crank the opposite direction about 1/4 turn. Easier to pack it off the motor
Huh,? I'm lost. Always used the hex tool.and drill. Not knocking you, at all, but I like to learn new or unorthodox ways.Primed a small block yesterday,,,,poured a small amount of oil in the pump went I assembled it a couple of weeks ago....I use a speed wrench and turn the pump by hand....after a few seconds of cranking I had 60 psi of oil....
So a hex head socket, and a hand twist ?yes....hex tool...and speed wrench......
Ive heard packing the oil pump with molly lube before installing and it will prime itself. Also if you use a differential fluid pump you can pump oil into the pumps outlet (outside threads) prior to installing filter and it will prime.
I think we have different terminology for things... us un- ed- ucated Southern Simple folk just talk funny. But we have 5/16" hex head sockets, on the male end, for 3/8" drive applications.... and Grandpa's ol spinner...
Tks.
make sure you got the oil pressure sender in or blocked! I did that with a drill and got a guyser of 30w right up my left nostril. Not comfortable!
really.....lolmake sure you got the oil pressure sender in or blocked! I did that with a drill and got a guyser of 30w right up my left nostril. Not comfortable!
No.....i have been doing this by hand for many...many years.....like the feel went it stiffens up......Is your drill broken?![]()
I had primed mine after engine was installed and without a pressure gauge. Had oil to all rockers. Slapped on valve covers and distributor, then fired it up. Mine is hydraulic roller cam and the lifters were reused from it’s previous build, so I was not too worried about break-in. Started and ran well but had lifter or rocker arm noise from left side.Thanks for the tip mate, love the hex socket and wrench combo
How did you discover that you forgotten it? I found out after I fired the engine up. It had oil pressure but lower than I'd like. Bedded cam in and engine oil got warm and oil pressure suddenly dropped to nothing so I shut it down. Engine sounded fine, cam has all it's lobes, but yeah wasn't the best situation.
Edit: Job done - this was the best tip ever. Wacked some sealant on the threads, plug in place, hex socket and spanner and screwed it straight in.
does that mean the cam has to come out?going the right way? Probably the oil galley plug is missing under the distributor mount.
Need some help, oiling issue 318 la block with magnum heads
ran into that on a GM...Oldsmobile i think it was, put the wires on with the Chevy firing order 18436572, oh yeah thats the firing order just going counter clockwise...WTF LOL!As long as you know that the right way is the wrong way on a big block. As in the pump turns anti-clockwise on a big block.
do tell.....like the feel went it stiffens up......
