Yes, they do. But as of now, the engine's been through at least two owners that we know of. So who knows what who did?
Yeah you get the idea. lol
I was thinking rear brake or rear end dragDid you leave the E brake on?![]()
Yes. every single one. thanks!Just asking, does Blueprint dyno every engine? If so, you don't need to touch it. Install it and destroy tires.
if you have a tach, roll down the block in drive very slow and slam it to the floor! While watching the tach. Should be pretty close to your flash stall point.The guy I bought it from did an 80% restoration, doing most of the work himself. I received a ton of paperwork/ receipts and while I found the receipt for the 904 from TCI, I cant find one for the torque converter. How can I find out what size it is? Suppose I can call the dude...
Like I said Mopar Vince installed it and Blue Collar Customs in Sacramento did the timing and tune last week. The power mostly shows up after 2500rpm, it's just the getting started part. At idle and throttle, you wouldn't know there's a problem. Sounds great.
Performance wise, it is tame enough to drive daily but has enough power to light the tires at any time. I am super happy overall.
thanks, missed that!OP states 3.23’s in the first paragraph
I had to re-read it myselfthanks, missed that!
but what I did read hasn't mentioned anything about where the cam was degreed in at.....I'm wondering if it's retarded based on what the OP has said how the car acts.
Another thing was the need to use the bolt on timing mark pointer from my 273 and to make the new mark on the harmonic to match because I used the early style short water pump with the lower hose to the radiator on the driver's side.
