Now that spring is finally here and it does not get dark till 8:30 pm,I have devoted 1 hour minimum on my darts after work.
I been main concentrating on my 63 GT.
In this past week I sanded and painted my small bolt ralleys,got tires mounted and balanced (traded the rice burner rims that came on my 66 dart for new tires 215/70-14).
Removed gas tank ,PO screwed up the sending unit pickup and drilled a hole in the bottom of the tank and screwed a fitting in the bottom...
Installed new tank and sending unit and replaced all the rubber fuel lines.
Fixed drivetrain vibration,PO had the tri union rebuilt and drive shaft balanced and with rear tires in the air that driveshaft looked warped.Ujoint on rear was not center in the straps to the rear end..Easy fix !!!
I replaced the brakes front and rear last year with wheel cylinders,shoes and master cylinder,so I finally bleed the brakes.
This slant six purrs !!!
Just drove it around the block.
No it is time to fix my rear lights !!! So I get it inspected and plates and it will be my daily driver...
On my 68 dart,I pulled the carb and put a rebuild one I have on it.
Tomorrow after work I will be installing a ignition switch in it and working on the fuel system,dropping tank,cleaning and replacing rubber lines,I already got her running off carb cleaner,she been sitting 12 years.
No longer waiting for weekends to get stuff done !!!
