Why do people think their 440’s are so fast. Lol. My stock block Edelbrock headed 408 has beat a lot of 9, 10, 11, second 440’s with a lot of good parts in them.
Indy Aluminum block 472 carb to pan 480 lbs.I like them both, and they both have their own pros and cons; but I really wish people would stop comparing weight between a stock iron headed, iron manifolded small block to an aluminum headed, manifolded and T.C.ed big block. Keep it apples to apples. Throw the same equipment on a small block- aluminum heads, manifold, etc. and the weight difference is still gonna be there; just at lower numbers.
Heck, throw an aluminum block and enough other parts into the 440 and you can probably get the weight down to that of a stock (iron block) slant 6... but that defeats the whole comparison.
To the OP:
As said, do what you wanna do. Sometimes it's for no reason other than "that's what I want/like". Damn the torpedos, full steam ahead... You don't need any other reason than that, as long as you're aware of the practicalities and your own possible limitations (abilities, finances, availabilities).
Point is, there isn't a "massive" amount of difference. 440 source heads are factory design and are really only a little more than re-doing the factory cast. Just in that, were only talking about a 15 - 30 lbs difference on a RB block. So, while I'm not arguing to stick the 440 in there (I actually said the 360 for his intended purpose), there is not this massive- "can't turn a corner without tipping the car over" difference that so many make it out to be. There is more of a difference between a small block with AC than the RB. We think nothing of the factory AC as far as handling, the RB is really less than that of a difference.don’t know if you know what you’re now arguing. Your video on cylinder head Wright verifies my weight estimate of a pair of big block heads at 102 pounds….
the rest of this is just math:
Aftermarket aluminum big block heads are about 60 pounds for the pair.
a stock assembled RB weight is approximately 670 pounds.
a stock assembled 360 LA is approximately 550 pounds.
That’s a difference of 120 pounds making the LA lighter.
even if you shaved 40 pounds off an RB by using aluminum heads it still makes the 360 LA LIGHTER by about 80 pounds…
All of this is just the engine. Keep in mind the rest of everything else behind and around the big block also weighs more too.
big blocks are cool, I have them too, and will have more and all of this is to each their own. But small blocks in an A body is easier to work on and lighter
EDIT; fyi, the original video of that’s 408 weight shows it has all the front end accessories and motor mounts and Everything on it too. all my comments involved stock weights. Furthermore if you want to compare apples to apples put all that whizZy aluminum stuff on the small block and make the comparison equal it will weigh LESS….
Power is for speed.Good Morning all, so I was B’s deep in my 74 Dart Swinger, planning on a 440 swap…along came a sweet 69 Swinger with a 360 that I bought and now selling the 74.
I bought a 440 builder, tore it down and had it bored .030 over, cam/crank tunnels aligned, new cam bearings, completely balanced, have new pistons, the a body oil pan kit, Schumacher headers, cam.
But the 360 is in there, I do need to get the correct flex plate as there is a bit of a vibration, and it’s a tired motor.
Now I’m not sure if I want to:
Just refresh the 360 with new gaskets, bearings, rings, new cam. And possibly do a torqstorm supercharger down the road.
Go 408 stroker.
Or just do the 440.
I’d love the 440 but now I’m concerned with how much of a bit*h it would be to work on after already working on the 360 a bit.
It’s just a street car to cruise/ haul a** around in.
Just curious on opinions or those who have been in the same shoes?
Also, I wouldn’t be selling the 440, I would keep it and one day find a W-150 or maybe even B body to toss it in.
The point is no one is saying a stock small block is too much weight so by time you swap intake headers etc.. on the big block the weight is similar to the so called acceptable stock sbm weight.I like them both, and they both have their own pros and cons; but I really wish people would stop comparing weight between a stock iron headed, iron manifolded small block to an aluminum headed, manifolded and T.C.ed big block. Keep it apples to apples. Throw the same equipment on a small block- aluminum heads, manifold, etc. and the weight difference is still gonna be there; just at lower numbers.
To the OP:
I have a 2 headed coin he can flip ...Flip a coin. One has a little more wow factor opening the hood and the other fits the car better.
If you don’t run a small block stroker, yer dumb and everyone knows the big block mopar ain’t nothing but a boat anchor. I smoke 440’s in my 302 headed 318 all day long.
..LOVE IT!!!Stroked small blocks, in my mind that's what makes the 383 and 400 a small block in today's world, only with a bigger bore and short strokeI like when people build a 400+ cid small block and act like it's still a small block and somehow they won with an underdog, yes technically you got a physical sbm but if we're comparing engines with heads that have similar power potential eg.. 600 hp what's the difference 340 vs 440 vs 543 vs 416 they're all gonna be capable of 600 hp just at different rpms.
But for the OP building a streetable say .9 to 1.2 hp per cid
360 = 325 to 430 hp
445 = 400 to 535 hp
And a refreshed 360 ain't gonna be making over 400 hp
The OP dealing with what he's got now not some imaginary 408 build, plus why spend money on a sbm stroker kit when he could put that money towards a great top end for his already rebuilt 440 short block.
It's all in the bore and stroke and nothing else. You pretty much said it.I like when people build a 400+ cid small block and act like it's still a small block and somehow they won with an underdog, yes technically you got a physical sbm but if we're comparing engines with heads that have similar power potential eg.. 600 hp what's the difference 340 vs 440 vs 543 vs 416 they're all gonna be capable of 600 hp just at different rpms.
360 = 325 to 430 hp
445 = 400 to 535 hp
Im glad someone got it!![]()
..LOVE IT!!!
572 cubes of pure badass.
