Overlap vs. Wider LSA - Detonation Resistance?
Just looked at Total Seal gas ported AP steel 1.5 1.5 3.0, 4.03+5 bore, $642.00. Outta my league!!! Maybe for a class racer where every horsepower counts.
If you actually used them and tested with them you’d see the value. I get it. They have damn near doubled since I bought mine.
The last set I bought was over a year ago and they were 420 or something. It took a bit to convince the guy of the value of them but he is happy now.
Depac ADL. No longer available. If you are looking, I would look at Your Dyno. I talked to them at PRI again this year and there booth was very busy. They have probably the closest load control to a Depac ADL. Alot of dynos i hear on YouTube sound like they are going up stair steps. The Depac doesn't do that and has good control below peak torque. All brakes need good supply of water to the brake. I have a pressure tank mounted near the valve after the pump to ensure a good water supply.
These pistons are 1/16-1/16-3/16. It’s what I had.
If I get my choice I’ll take an .043 ring and better yet the 1mm (.0394) ring pack.
Rings eat power and make heat.
1/16 rings are the new 5/64 tractor ring.
It’s why I avoid KB pistons like the plague. You can’t even get a 1/16 ring pack with them.
Thinner rings seal better, last longer and make more power.
Preach that.
When you run a roller cam over a hydraulic flat tappet stick it also changes the whole dynamic.
The roller allows you to open and close the valves so much faster.
While wider rings do eat horsepower, they are a lot more forgiving in an engine that detonates over the skinny rings.
Tom
Keep your junk out of detonation. It’s that easy.
What brake and load control do you have now?
I’m using Performance Trends. I have his new servo controller and it’s fantastic.
I’ve never used Depac so I’m curious about how Dave set up the controller.
Is it like SuperFlow does it where the valve forces the engine to maintain a set acceleration rpm or is it like PT and I believe YD where the servo valve opens at a constant rate and the engine will rpm at what ever rate it can?
I watched a Darin Morgan webinar on Drag Boss Garage and he had some comments about that.
I didn’t get to see that one live or I would have asked some questions about it.
Why don't you just buy is all some?
Actually, the SF901 will do it either way.
I’ve never used a SF newer than a 901, but I assume they still can too.
Oh, and I still like moly filled ductile top rings for a lot of applications.
I need to get out my SF book and have a read through it again.
Darin Morgan brought it up so I need to watch that video again.
I prefer the controlled rate, so I haven’t used the other method in ages.
Basically, you’re doing pulls in the “manual mode”, which allows the servo valve to open at a linear rate, which is still selected by the rate knob.
The sequence to get the pull started is a little “clumsier” until you get the hang of it.
Do you mean open the valve at a controlled rate or keep the engine accelerating at a set rate?
Also, are you using STP correction factor or something else?
In the manual mode, the valve itself opens at a constant rate, as opposed to the variable rate that’s used to control the acceleration rate.
At the switch for the control valve-
Servo = valve is controlling engine accel rate
Manual = valve opens at a steady rate
Like I said, I haven’t done it years……. But I think there might be a position for the knob that controls the type of test(accel, step, etc)…….maybe “manual”?
If not, it might still be done in the accel position.
J607
The dyno is at about 350’ elevation, so the c/f is often only about 5%
J607
Thanks.
I’m being told that J607 has issues when the correction gets over 6% or close to that.
It goes out of scale as I’m being told.
If I test at 6% that would be Disney land for me. I think 7% was the lowest CF I’ve seen.
I’m thinking about using a “newer” CF just to compare the numbers and see if the really do get out of scale.
There are guys out there who think if you aren’t testing at the F1 level the testing isn’t valid.
I’m just trying to understand if the CF is that wonky or not.
I’m probably going down a rabbit hole I don’t need to but…
We’ve got 28 years of dyno data using J607……… kinda too late to change now.
We try to only compare to other engines tested here.
When an intake or cam is swapped, and one is better than the other……… the better one is still better……. Whichever c/f is used.
I should clarify something…….
While we really only look at the J607(STP) numbers, the dyno always processes another c/f J1349(SAE), which is corrected to like 77* and 29.23”.
It’s there, we’re just not using it.
I see fairly often shops with newer dynos using inertia corrections as well as corrections for weather.
Obviously with vs without IC, the numbers will differ.
