Treb is spot on. New engines are picky about initial timing. 10° before to start initially might be good or it could be too much. Once it starts and stays running I usually turn the distributor to find that sweet spot where the engine doesn't labor and runs smoother and faster. Break in the cam and then reset the timing back to 15° or so to begin your initial settings.
