Public service announcements. Please don’t use these.
pittsburghracer
Legandary Member
Legendary Member
Freeport, PA.
You know what I’m talking about. Those hard to resist gasket removing buzz wheels that take gaskets off faster then, well let’s not go there. While nicely removing those gaskets you are also removing the nice flat gasket sealing surface on heads and intakes. We all hate this job but please guys learn how to remove gaskets the “right” way.
Ooh, I hate when people bring in heads for surfacing or any type of work & they've been cleaned up with a wizzy wheel. It makes a ***** and a half to get them set up and hardly ever get lucky enough to nail a clean 1st pass.
I use a flat square edge carbide scraper only and very gently scrape.
Super scrapers are cheap on Amazon. I have had the original wood handle ones for 10 years and they still work as good as new and get used almost daily
I'll have to check those out, my scrapers hurt my wallet off of the Cornwell truck.
Just checked them out I agree when mine wears out I'll get those
Screw that. Let um do it and find out the hard way.
Lol, I've had to weld aluminum heads because of idiots trying to remove their own gaskets, so called mechanics too (used car dealer mechanic)
I’m pretty handy with a single edged razor blade. I go through about 400 a year. Mostly body work though I use them for gasket cleaning. And cuticle trimming. Lol
3M Scotch Brite?
A guy at work has the cheaper plastic handled ones and they are made just as good. The handles just aren’t as comfortable
I like a razorblade scraper. You can't get violent with them but the blades are so thin, sharp, and flexible it will slice through about anything.
The carbides are about perfect as long as you hold them nice and flat
True but you have to remember, carbide is harder than the cast iron surface. It is easy to scratch and gouge if you're not careful.
GM had a lot of bearing failures under warranty. Most of the failures had a intake manifold replaced or resealed prior and #M Scotch Brite pads were use. They switched to Bristle Disc and the issues went away. WOW I sold cases of these.
Is it any different for cast iron block and head sealing surfaces as opposed to aluminum? I saw a video recently where Steve Dulcich was using a wire wheel to clean the deck surfaces of a block.
bristles disc. Thanks. Couldnt remember what they were called. An almost worn out black flexible abrasive disc makes short work of most freeze plug holes or whatever you want to call them.
Let me edit this real quick,We use a wire wheel on blocks, works well but that's only before boring and honing and it goes in the hot tank and pressure washed afterwards .
Ford's suck they had asbestos gaskets so wire wheel is a no go !
i bought the super scraper 3 piece set 20+ years ago and it still works like day one. it was dough then, and it's still dough now but a great investment.
titan and ares make a really decent 2 piece set that are very comparable for sub $30
Bristle discs are THEEE best! I knock off the main chunks with the standard scraper first; but let the XX,000 rpm do the finish work!!!
